47Rh HELP!!!!
Old Apr 21, 2012 | 05:26 PM
NauticaEE's Avatar
Default 47Rh HELP!!!!
Hey guys I bought what a guy called a 47rh and it seems to have alot of more plugs onit than i would imagine so i was wondering if someone could tell me some ways of identifying it, thanks alot, also, do i need to run a shim between the transmission and the adapter? thanks!!!
Old Apr 21, 2012 | 08:00 PM
Fire Power's Avatar
A pic might help
Old Apr 21, 2012 | 08:20 PM
NauticaEE's Avatar
hmmmm ok ill try one sec
Old Apr 21, 2012 | 08:24 PM
NauticaEE's Avatar
did it work?
Old Apr 22, 2012 | 04:08 AM
huricane's Avatar
the plug at the botom of your shifter is neutal park switch the one closest to the main trans body is your lock up and the one on the tail is speedo it is an rh
Old Apr 22, 2012 | 07:04 AM
welderboy250's Avatar
Iirc, the neutral safety switch also turns on reverse lights
Old Apr 22, 2012 | 01:26 PM
NauticaEE's Avatar
awesome, now next question, do i need to have a shim in between the bellhousing and the adapter? also will a dipstick from a 47re work? i mean dipstick tube and dipstick? thanks alot!
Old Apr 22, 2012 | 08:34 PM
huricane's Avatar
the dipstick and tube will work fine and you should not need a shim
Old Apr 22, 2012 | 08:39 PM
NauticaEE's Avatar
well as luck would have it that one sold what about a 46re? will that tube work? thanks!
Old Apr 22, 2012 | 08:50 PM
huricane's Avatar
the dipsticks are the same
Dudeman
Apr 5, 2015 10:28 PM
davidthomas
Mar 24, 2015 12:41 AM
02Stain
Feb 18, 2015 10:02 AM
rtbcoop
Dec 30, 2014 02:13 AM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
