star wheel playing info I need by doing so
Old Apr 19, 2012 | 08:22 AM
Chad96Dodge's Avatar
Default star wheel playing info I need by doing so
Okay so I turned my idel up a wisker to get it up above 500 rpm now im sitting pretty good sounds good starts good. Okay what I want to know is iv done reading a little I just want some feed back from yall I mest with my star wheel by doing so am I putting my truck in danger by any means? i turnd it tureds the motor a couple times I tried to make a mark on it but was hard so I just went for it. I get some black smoke now but just a little right as I get on it then its done. I just want to know is that going to hurt my truck do anything with EGT or is this such a small mod that it wont hurt a thing thanks so much for the info
Old Apr 19, 2012 | 09:36 AM
sweetv8s10's Avatar
I would say you will probably be ok.
Old Apr 19, 2012 | 01:01 PM
ricet07's Avatar
You will be fine.
Old Apr 23, 2012 | 11:27 AM
Sweet thanks guys. My truck feels like a new truck now its awake the throttle respons is there love it. Thanks for all the help I am learning a ton about my truck on here
Old May 6, 2012 | 10:47 AM
cummins 12's Avatar
Well while yall r talking about star wheels can I turn my star wheel up with the stock fuel plate or will it mess anything up
Old May 29, 2012 | 04:19 PM
I turned mine with the stocker plate. Runs just fine. all it does is start fueling the truck at less boost. Do some web surfing there is tons of info out there. Thats wher I got mine but alos on here. Turn and play I did it 3-4 times befor I found the spot I liked
Old Jun 10, 2012 | 08:57 AM
cummins 12's Avatar
Ok thanks man
Old Nov 6, 2012 | 07:55 PM
Jamsee251's Avatar
what is the difference in turning the star wheel up or down? i know turning towards the motor is more smoke what does turning towords the battery do?
Old Nov 6, 2012 | 08:54 PM
TheMacster's Avatar
turning it towards the battery compresses that spring adding more tension taking more boost pressure to move rod and foot
Old Nov 8, 2012 | 02:36 PM
mattestcali86's Avatar
what way should i turn it for more power
