voltmeter surging
Old Apr 18, 2012 | 10:08 PM
guyser79's Avatar
Default voltmeter surging
I've got a 93 Cummins that surges when I start it. I know its supposed to do this when its cold out, but its 55 here. Anyways it goes like this: When I start the truck and turn the lights on the volts crank up and then there is an audible "click", at which point the lights dim and the voltmeter goes back down to say 8. It does this a few times and eventually stops surging but the voltmeter is pinned up at 14. Any suggestions? I have had a external voltage regulator put in a few years back because the truck was doing the same thing. Could it be a faulty voltage reg? Thanks fellas.
Old Apr 18, 2012 | 10:26 PM
tiremann9669's Avatar
I think it's the grid heaters cycling.
Old Apr 19, 2012 | 06:12 PM
guyser79's Avatar
how long will it cycle like that? I haven't driven longer than five minutes into work and back, so I don't know if it will stay up around 14, or should it cycle back down?
Old Apr 19, 2012 | 09:31 PM
Budgreen's Avatar
might want to check the temp sensor.. water temp i think triggers it? but a faulty temp sensor would let them cycle, and will keep cycling till that sensor reads a "warmed up" temp.
Old Apr 20, 2012 | 03:26 PM
cougar's Avatar
There is a separate temperature sensor for it in the intake manifold. Your grid heaters should not be coming on at 55° so the sensor is probably bad. The temperature threshold starts a timer in the PCM that cycles the grid heaters in decreasing intervals.
Old Apr 20, 2012 | 03:54 PM
sweetv8s10's Avatar
The grid heater will cycle if its below 60 degrees outside until the truck warms up.
Old May 11, 2012 | 08:39 PM
Daves1stgen12v's Avatar
Im having the same problem with my truck
volt meter goes to 18v and it pins and the lights in the truck get super bright, sometimes like that for 5 10 15 min. Measured the volts at the batt when it happen, 17.6 ish volts to the batt.
If the grid heaters are not hooked up will it still cycle or can i unplug this temp sensor and see if it stops?
Old May 16, 2012 | 07:49 PM
flyingcrodeo's Avatar
It's the voltage Regulator is what I think but while your driving does it stay up high like 14, 16 or so? If you don't find the problem quit it might kill your battery.
john grossman
10
Jan 12, 2019 08:58 PM
boneheaddoctor
Jan 15, 2016 06:19 PM
MIKE3822
Nov 4, 2014 07:34 AM
Jclamorgan
5.9L 24V Performance
Sep 27, 2014 09:47 AM
