Common brakes and power steering goes out!!!!
Old Apr 17, 2012 | 12:33 AM
cumminskilla's Avatar
Default Common brakes and power steering goes out!!!!
How's it going guys!
Driving down the street today and brakes along with power steering went out!!! 1999 cummins 5spd
Then coasted into the curb
I looked under the truck and there was powersteering leaking like crazy
Till completely went out
My question is what is it and hard fix???? ( steering box, vacuum pump ? )
I understand this is a common thread but nobodys actually leak
Help please!!!!
408-417-5766 if possible daily driver need asap
Or post thanks!!!!!!
I can get a pic first thing in morning
Last edited by cumminskilla; Apr 17, 2012 at 12:33 AM. Reason: Automerged Doublepost
Old Apr 17, 2012 | 10:39 AM
daveO's Avatar
A pic would definitely be helpful.
Old Apr 17, 2012 | 11:02 AM
turbo2332's Avatar
you coulda just blown a line for your hydro boost? pumps still pumpin but it aint going where its suppost to, then you run out of fluid and loose your power steering. thats where i would start.
Old Apr 17, 2012 | 04:04 PM
I'm getting pic right now and it leaks like crazy so has to be this part
Old Apr 17, 2012 | 05:50 PM
JBearSVT's Avatar
Mine did that last year, and it was the line to the hydroboost too.
Old Apr 19, 2012 | 02:34 AM
heres the picture it leaks 1005 all powersteering fluid from here and started to leak a bit an hr before they both went out completely
the power steering and brakes
what is this part? where do i find it? how much and can out together myself ect
Attached Thumbnails Common brakes and power steering goes out!!!!-imag0848.jpg
Old Apr 19, 2012 | 02:36 AM
sorry about late picture couldnt upload
BUMP
Old Apr 19, 2012 | 09:26 AM
BarryB's Avatar
I couldn't tell much from the pic. Is it coming from above the pitman arm? With out seeing it in person, the pic would make it look like it is coming from the seal around the output shaft from the steering gearbox. Is the top of the gear box wet from PS fluid? If so it could possibly be a hose.
All the parts can be gotten at just about any parts store to answer you last questions. Depending on you wrenching skills and selection of tools available it can be done at home. might take some longer than others.
Old Apr 19, 2012 | 02:33 PM
Yes the steering box I believe its called
The pitman arm is connected to it and that little seal is leaking excatly what you
said all fluids coming from the bottom right where it connects to the arm!
Can I just take pitmam arm off then get that seal off and replace with new part and it will stop
Leaking then fill with fluid and good to go?????
Old Apr 19, 2012 | 08:45 PM
BarryB's Avatar
got to admit, I've never had to replace a leaking output shaft seal on a steering box. I'm not sure exactly what type of seal is in there. Some reason it comes to mind it is an internal seal. My opinion would to take that to a shop.
