egr cooler vs delete questions
Old Apr 16, 2012 | 06:27 PM
brondondolon's Avatar
Default egr cooler vs delete questions
i have an 03 f350 6.0 with 95k miles and im getting egr codes again after i deleted them and cleaned the egr. in the oasis report it says that its had an egr replaced twice but never the cooler so here are my questions
does a egr delete have any mpg/hp gains
if i go with the bullet proof cooler is mine the square or round one
im in california if i go with a delete does any one know where i could get it smogged if you catch my drift
the codes came after i installed my mbrp straight pipe could it be throwing these codes because ive had a really heavy foot lately?
thanks guys
so i just pulled my egr off and checked inside there is soot like normal but there was a glob of what looked like grease so im not sure if my cooler is leaking but i have no idea what that grease thing is??? it was about the size of a dime btw.
Last edited by brondondolon; Apr 16, 2012 at 06:27 PM. Reason: Automerged Doublepost
Old Apr 16, 2012 | 08:37 PM
DavidWulf's Avatar
Hey the 03 coolers rarely if at go bad it just doesn't happen , if your in cal leave it alone or weld it shut then it appears to be stock but don't know if it will pass sniff. But really you can't hardly tell a diff when its gone . And also need to leave EGR valve in and plugged in to keep fan operational. A lot of people don't know that one.
Old Apr 17, 2012 | 07:23 AM
Lilpooh's Avatar
The '03's have the round EGR cooler. Another thing with unplugging the EGR valve is, with the '03-early 04's if your running a VXAP strategy the VGT will not go thru the vane cycle when at idle.
Old Apr 17, 2012 | 10:25 AM
Mdub707's Avatar
If you found any sort of wetness in there, the cooler is leaking. Do something about it sooner than later. If I was in Cali, I'd either do the BPD bulletproof cooler, yours would be round, but I'm pretty sure you can use either cooler in there... or just take yours out and have some stainless plugs welded into it to close it off. That way it's "blocked" but visually it's still there.
Old Apr 17, 2012 | 05:08 PM
I can weld and I have a welder what exactly is to be welded? just the inlet and outlet for coolant?
Old Apr 17, 2012 | 05:37 PM
Mdub707's Avatar
Yep, get some stainless plates cut in a circle to fit in there. You can even use freeze plugs, but on the exhaust side make sure you fill that sucker up with weld, cause the freeze plug wont take the heat alone.
Old Apr 19, 2012 | 11:23 AM
EricC's Avatar
I took my egr valve out should I put it back? I heard someone say that u can plug them in and just lay them under there??
Old Apr 19, 2012 | 12:22 PM
Mdub707's Avatar
I took mine out too. Haven't had it in for some time. Thought about putting mine back too, IDK. You can either just plug it in and zip tie it out of the way, or just put it back in the intake, it wont make a difference there is no way for exhaust to get to it anymore. Might as well just drop it back in the intake manifold and bolt it down at that point.
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
dscp
Apr 17, 2015 02:51 PM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
