ECT and EOT "tee" Fittings help
Old Apr 16, 2012 | 03:27 PM
txf250's Avatar
Default ECT and EOT "tee" Fittings help
Im putting in a set of gauges and i was wondering if anyone knew what size tee fittings i need for the factory water temp sensor and factory oil temp sensor its going on an 05 f250
thanks
Old Apr 16, 2012 | 08:45 PM
DavidWulf's Avatar
I don't know about the fittings but if i were you just can the dial gauges and get a SCANGAUGE 2 159 at auto zone it will read your ETC and EOT's off factory sensors and be more accurate. And it also reads ICP,IPR% trans temps , FICM volts, and more stuff than i can type right now , you can't beat it for the money.
Old Apr 17, 2012 | 08:47 AM
Mdub707's Avatar
What gauges do you have? My Isspro EV2's came with all the fittings (well, at least the coolant gauge I bought from them). I believe you can also tap into the coolant filter housing for coolant temp if you want. I have also seen those T's for the coolant lines, but can't recall any for the oil lines. You could get one of the billet caps for the oil filter that are pre-tapped and put your gauge in there. The cap's are like $50 on ebay. Dieselmanor.com is also a good place to look for gauge accessories, or at least get the info from them, just don't forget the DB sponsors when it comes time to purchase something.
Old Apr 17, 2012 | 09:26 AM
txf250's Avatar
I bought the glowshift 3 in 1 gauge. I guess ill just have to take the sensors ou
