power windows in accessory
Old Apr 16, 2012 | 02:25 PM
wyodiesel92's Avatar
Default power windows in accessory
Just thought about it but couldn't I make my power windows work in accessory and ko instead of Just ko by running a jumper from an accessory powered and ko power to the fuse for the windows? Or would I be running more amps when ko?
Old Apr 17, 2012 | 05:34 AM
Devon527's Avatar
I'm in for this, i want my Windows to work on accessory too.
Old Apr 17, 2012 | 04:35 PM
Someone has to either done it or knows more on auto electrics then I do
Old Apr 17, 2012 | 04:49 PM
Whit's Avatar
Site Mascot
I simply jumpered over to the fuse with acc power
Old Apr 17, 2012 | 05:19 PM
RAW's Avatar
RAW
This is something that I may have to do. It has a lot of upsides to it.
Old Apr 17, 2012 | 10:15 PM
That's what I was going to do is just jumped from an acc powered fuse to the power windows. Maybe ill try doing a real clean job from behind the fuse panel and do a write up
Old Apr 18, 2012 | 08:27 AM
RAW's Avatar
RAW
A write up would be great! It would find it's way into the Tech section.
Old Apr 18, 2012 | 05:40 PM
Ill try and do one in the next couple days
Old Apr 20, 2012 | 05:01 AM
Devon527's Avatar
I just did this today, jumped a wire from the wiper fuse to the window fuse. works like a charm and way more convenient!
Old Apr 20, 2012 | 10:49 PM
Started looking at doing it under the dash or the back of the fuse panel and doing a jumper actually from fuse to fuse might be easier. Im going to look at wiring diagrams and see if there is a cleaner way I can do it without taking the dash apart
OBSBEN
Jan 9, 2015 04:35 PM
explorer197143
Dec 28, 2014 01:14 PM
