Won't hold prime
Old Apr 15, 2012 | 10:23 PM
fenceman's Avatar
Default Won't hold prime
Replaced my lift pump. Cracked my injectors and got er fired up. Drove it to the store. Maybe 15 min. in the store, came out and no start. Had to crack em again to get er going. Any ideas?
Old Apr 15, 2012 | 10:33 PM
Drive it a little longer. Sounds like u still have air in the system
Luke
Old Apr 15, 2012 | 10:37 PM
Whit's Avatar
Site Mascot
Luke
yes.....great advice
Old Apr 16, 2012 | 03:11 AM
empty wallet's Avatar
If it was running smooth probably not air... Which lift pump do you have? Common causes for leaking back are return on vp44 is worn out or the return line on the back of the head (injector overflow) is leaky... What was it doing before pump was replaced?
Old Apr 16, 2012 | 04:25 AM
russellflemister's Avatar
Also look into replacing the fuel return bango bolt on the injection pump I had the lose prime problem replace fuel return bolt and fix the problem
Old Apr 16, 2012 | 12:35 PM
fenceman's Avatar
It fired up this morning with a crack of 1 and 3, ran it to work. No problem. Went to the site and it sat for 45 min. and would not start. Cracked them again, got good flow but still would not start. Towed it home and will try the banjo and return line ideas.
Thanks
Old Apr 18, 2012 | 01:58 PM
DanH's Avatar
I'm sure you've already done this, but everytime I've taken off a banjo bolt that's been on there a while, they tear. I chased this down for a while the first time I tried to reuse gaskets(should have known better). Mine was doing the same thing when I put a new lift pump on. Also, it would feel like it was running good with the air leak, but when it was finally fixed, you could tell the difference.
Old Apr 18, 2012 | 11:05 PM
hulse09's Avatar
my truck is doing the same thing. i changed my filter once and then it would not start. cracked the line and got it going. but not its had to start. i hv to bump the starter 3 or 4 times and let my raptor lift pump run then it normaly starts but been a few times i was she almost didnt go. im thinking thh banjo bolt is not tight and is there a gasket on them.. but there r days it will do it then days it wont.
Sep 29, 2015 02:40 PM
NSmachine44
Aug 16, 2015 09:25 PM
joejack6.0
Apr 29, 2015 11:45 PM
cumminsblazer
9
Apr 8, 2015 10:42 PM
Baradium
Mar 9, 2015 07:15 PM
