Tall tires
Old Apr 15, 2012 | 09:45 PM
Dozey's Avatar
Default Tall tires
I have a 92 2wd 5 speed with 3.54 gears. Now I like to kinda day dream because I don't really have the money to do much of what I'd like like a gear vendors and such. But I have always liked the look of tall narrow tires. How tall of tires has someone been able to stuff under their 2wd? I believe at one point I found a 2 inch lift for the front to level the truck thinking I cant now fit taller tires. Also at one point I found actual baja fenders found 1st gens. How tall of tires are you guys able to fit under your trucks? If taller what mods are you doing to fit taller ones?
Old Apr 15, 2012 | 09:48 PM
Whit's Avatar
Site Mascot
2inch up front and you can jam 35 inch tall under there
Old Apr 16, 2012 | 03:38 PM
1stgenblowingsmoke's Avatar
On a 4wd yes not a 2wd. Prob 32's.
Old May 10, 2012 | 11:54 PM
Gas's Avatar
Gas
Stock 235/85 are 32"
Old May 11, 2012 | 06:55 AM
welderboy250's Avatar
235/85-16 are closer to 31
Old May 12, 2012 | 10:53 PM
tiremann9669's Avatar
The chart I use says they're closer to 32, 31.73 if it matters
Old May 12, 2012 | 11:10 PM
PSD-BLACK-CLOUD's Avatar
Do you want the front and back to be the same size is the question?
Old May 22, 2012 | 07:00 PM
Dozey's Avatar
I wouldnt mind if the rear was a little taller. Since the leveling kit would lift the front. the rake can be put back with taller rears.
Old May 22, 2012 | 10:37 PM
Edahall's Avatar
Go look for some 285/85/16 tires.
Old May 23, 2012 | 05:42 PM
He said he wanted narrow tires, try 7.50-16's
