which head gasket?
Old Apr 15, 2012 | 11:50 AM
cummins95's Avatar
Default which head gasket?
im startin to put my truck back together after the blown head gasket. i found a shop to oring the head, but he wants me to bring the gasket im gonna use. im wonderin if i should just go with a stock gasket, 10 over, or 20 over?
Old Apr 15, 2012 | 11:55 AM
Red_Rattler's Avatar
High Tech Redneck
I put a stock thickness back on mine...
Old Apr 15, 2012 | 01:08 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i like the .020 over cummins brand
Old Apr 15, 2012 | 07:16 PM
cummins95's Avatar
alright so whats the pros n cons of the thicker gasket?
Old Apr 15, 2012 | 07:26 PM
Benjamin's Avatar
Bombardier
IIRC the thicker gasket is to offset any material removed from the head or the block to true it back flat.
IF no material was removed and you put a thicker gasket on it would lower the compression ratio a little bit, it would also alter the valve train geometry a little bit BUT would allow for more piston to valve clearance.
IF material was removed you want the thicker gasket so that the valve train geometry would be correct, the piston to valve clearance would be proper and the compression ratio would be "stock".
Adam65
Jan 9, 2015 11:50 PM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
turbodiesel123
6.2L & 6.5L Performance
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
