hx35 swap
Old Apr 15, 2012 | 03:21 AM
jdbigblue12v's Avatar
Default hx35 swap
i just picked up an hx35 off of a 1996 5 speed truck. it only has 99xxx miles on it but i do not know the exact size of the exhaust housing from a manual tranny truck. is it 16cm? and how much boost psi is safe to run through this turbo? just picked it up for 150$ so i cannot complain, eventually gonna do a hx40 hybrid.
Old Apr 15, 2012 | 07:11 AM
welderboy250's Avatar
All dodge p-pump engines I know of came with 12cm turbine housings
And I'm not necessarily saying its a good idea but I've seen several guys run 60 psi continually and not hurt the hx35
Last edited by welderboy250; Apr 15, 2012 at 07:11 AM. Reason: Automerged Doublepost
Old Apr 15, 2012 | 08:56 AM
Bryson711's Avatar
If its from a 94 to 98 12 valve it will have a 16cm, if its from a 98.5 to 02 24 valve it will have a 12cm, also I would not suggest hitting over 40 pounds unless you got head studs and a head gasket that can handle it
Sent from my DROID2 using Tapatalk 2
Old Apr 15, 2012 | 09:08 AM
Fire Power's Avatar
I never heard of a hx 35 on an dodge that had 16 housing lets see a pic of said housing
Old Apr 15, 2012 | 09:54 AM
turbo2332's Avatar
all hx35 and wh1c i have ever seen or read about have 12cm housings the hx40's have 16cm housings. and safe psi is 35 i would LOVE to see 60psi on a 35 saftey glasses and a bullet proof jock strap! LOL
Old Apr 15, 2012 | 10:01 AM
Fire Power's Avatar
I have seen 60 psi out of a 35 in my 99 that has a 96 12valve in it going up the mountain I have seen 1600+ degrees and 60lbs I just pulled it this winter and sold it to a local machine shop that made a 35 40 hybrid out of it and is using it. I think I had a good one
Old Apr 15, 2012 | 10:08 AM
turbo2332's Avatar
what a lucky SOB. the efficiency range is maxed in the mid 30's that poor poor little hx bet it sounded cool
Old Apr 15, 2012 | 10:10 AM
Fire Power's Avatar
It sure did scream and yes it was way past its efficiency range
Old Apr 15, 2012 | 01:43 PM
i never said it DEFFINATELY had a 16cm housing just asking if thats what it had. i will post pics later and pics of the swap. a i going to need anything besides a gasket between the turbo and manifold?
Old Apr 15, 2012 | 06:35 PM
1stgenblowingsmoke's Avatar
It will have a 12CM waste gated housing. All HX35's n WH1C's had a 12cm waste gated housing. hy35's had a 9CM waist gated housing.
I did the swap on mine yesterday cuz I had it to try n help with EGT's till I get a bigger one to help with the big injectors. I reused the gasket between the manifold n housing, it's just a flat piece of tin.
