converter will not lock up normally
Old Apr 14, 2012 | 11:15 PM
dieseldude848's Avatar
Default converter will not lock up normally
hey guys, the owner before me wired in one of those converter lock up switches, and i just realized that it will not lock the converter unless i flick the switch. so does wiring in a manual switch to command lock up get rid of it locking up normally when the computer tells it to?
Old Apr 14, 2012 | 11:32 PM
globalwarmingcontributor's Avatar
no... something is wrong with the wiring.... go through the wires... i hope your converter isnt all jacked up
Old Apr 15, 2012 | 12:27 PM
do you mean check the wiring of the switch?
Old Apr 15, 2012 | 10:23 PM
Yes
Old Apr 24, 2012 | 06:07 PM
ok so i checked all the wiring, and it was correct except for the jumper lead thats put in place of the trans relay. i put it in the correct spot, and gave it a test run still no lockup unless i flick the switch. and sorry for the week late reply, starter solenoid took a crap, and was waiting on a new one to come in.
Old Apr 24, 2012 | 07:55 PM
empty wallet's Avatar
did they cut the wire or did they use a scotchlok type splice connector? for whatever reason, cannot cut that wire to splice the switch in... according to suncoast. how was the jumper wrong?
Old Apr 24, 2012 | 11:19 PM
if you look at the link, the jumper was in the middle vertical line going to the bottom horizontal line. when i swaped it, it made no difference, and no the wire is T-tapped not cut.
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old Apr 27, 2012 | 03:47 PM
any ideas is to why it wont engage by its self?
Old Apr 27, 2012 | 07:11 PM
Russ Roth's Avatar
I cut my wire and it has worked just fine about 4 years now. Those scotch locks are junk IMHO.
Old Apr 30, 2012 | 07:45 PM
bump
cumminspwr11
12
Oct 17, 2021 03:50 AM
Wizbangdoodle
Ford Powerstroke 08-10 6.4L
Sep 26, 2015 02:47 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
