02 dodge gearbox
Old Apr 13, 2012 | 10:09 PM
ericl's Avatar
Default 02 dodge gearbox
ok i replaced my steering box on my 02 dodge diesel with a reman from local parts store . put it on blocked up the front end and turned wheels from lock to lock 40 times with mptor not running took it out and drove it made it about a half mile then steering got tight and brakes didnt want to work brought back jack it up again and blead the air out again i have done this four times now still cant get all the air out of steering pump . i have noticed if i turn the wheels straight then turn them to the right a little bit i get the same air bubbles everytime. i never had a problem before this. starting to think it is the remaned gearbox any help would b much appreiated
Old Apr 13, 2012 | 10:54 PM
wyodiesel92's Avatar
Do it with the motor running. That's the proper way to bleed it. Brakes are tied in with the power steering explaining your issue. Do what you've been doing but have the motor running while doing it to get the pump bled. Should fix the problem as long as you don't have any leaks
Old Apr 14, 2012 | 09:55 PM
ericl's Avatar
i have blead both ways engine off and engine runnin the only leaks i have is what is coming out of th power steering resivour. im goin to drain steering pump and try it again with motor runnin again thanks for the help
Old Apr 14, 2012 | 10:01 PM
You may have put alot of air in just from doing it with the engine off. Try redoing it with engine running. It may take a bit but you shoulnt have alot of issues.
Old Apr 15, 2012 | 10:17 PM
ericl's Avatar
thanks a bunch i will try it tuesday and let ya know how it turn out
Old Apr 19, 2012 | 10:10 PM
ericl's Avatar
thanks got most of air out, it turn now but going down the road the steering wheel kinda jerks to the right like its pulsing wanting to turn by it self thank u alot
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 24, 2014 08:20 AM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
