Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Safe to Buy?
Old Apr 13, 2012 | 06:44 PM
Great Horned Owl's Avatar
Question Safe to Buy?
Hi All,
I hope you can help. I am buying small (probably under 9,000 lbs. fully loaded) 5th wheel RV and need to get a truck to pull it. I have been looking for a '06 or '06 2500 with the LBZ. I would prefer 2wd, but they are so scarce that I will probably end up with 4wd. I have never owned a diesel, and my knowledge is limited.
Even though it is far more truck than I need, I just went to see a '06, 3500 dually, crew cab, LT1. It has 80,940 miles and they are asking $24,990. It runs nicely, and is absolutely immaculate.
The truck has a Bully Dog module which I think may be the Triple Dog GT Diesel Gauge/Tuner. I am concerned that if not properly used, it may have done some damage. Is that possible? Is it likely? I am also concerned that the truck may have other, less visible mods that might be detrimental.
The bottom line is that at 70 years old, I am not into tinkering. I just want a truck that will reliably move my wife, my 5er, and me around the country. Should I be considering this truck or should I keep looking? If I do consider it, what should I be looking at on it?
Thanks,
Joel
Old Apr 13, 2012 | 07:30 PM
j johnson's Avatar
id say stick with stock...should be alot less problems with it..just my 2cts
Old Apr 15, 2012 | 09:30 PM
BriteWhiteRam's Avatar
yep, move on if it has a tuner, you need to find one that is stock, a stock LBZ will last a really long time, they are plenty powerful and really reliable if nothing has been done to it other than regular services
Old Apr 15, 2012 | 09:40 PM
Budgreen's Avatar
The tuner at the top level has enough to wear the transmission out pretty quick, I don't know anyone with a tuner that has never run it full out even once just to see what it would do or if something would truly break..
chances are the truck will last a good long time, but the transmission will wear out a bit sooner than normal.
look for stock.
Old Apr 15, 2012 | 10:01 PM
Thanks guys. You have pretty much confirmed what I suspected. If only that price weren't so attractive. Oh well, I'll just have to keep looking.
Joel
Old Apr 17, 2012 | 10:13 PM
Joel
well if you buy it, and the transmission does go, you can get it rebuilt for about $4500-5000, and then it would last forever
Old Apr 19, 2012 | 12:12 PM
Budgreen's Avatar
honestly.. if you could get them to come down a few thousand due to it having the tuner, it would be worth it even if it decided to give out a few years down the road. good test would be to warm it up and then ROMP on it.. and if the 3-4 4-5 shift is good chances are it's got a good life left. if the transmission limps (sticks to third with error light) it's on it's way out.
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
Bigredpowerstroke
Apr 28, 2015 06:30 PM
Sziraki21
Jan 15, 2015 03:56 AM
Dec 1, 2014 01:00 PM
Nov 1, 2014 08:20 AM
