Cummins identification
Old Apr 12, 2012 | 10:59 PM
HE22871's Avatar
Default Cummins identification
I know this has been posted here a ton of times but I have got 2 questions about a couple of blocks I have.
The first is my 12 valve that is in my truck right now. I was searching (and praying) that there was no 53 on the passenger side of the engine and all I saw was "ABC". I can not find anywhere that has got a good wright up on all the casting numbers and casting flashes. Its in a 95 3500. Is it worth holding onto?
The second question is I also have a 24 valve block that confuses me to no end. First it has a ton of reinforcement castings all over the outside of the block where the water jacket is curved for the cylinders. Also the mechanical fuel lift pump is towards the front of the engine not the rear. Also the crankshaft should have 6 bolts for the harmonic ballancer but only has 4 like the 12 valves do but it has a much better casting than the 12 valve cranks do and also does not have a reluctor ring on it for a crank sensor like the 24V should. I am baffeled by this should I call it bastard?
Any help would be AWESOME!!! Thanks guys
Old Apr 14, 2012 | 01:37 AM
cummin_un_glued's Avatar
FormerVendor
pics of the second one?
Old Apr 14, 2012 | 08:27 PM
welderboy250's Avatar
To be a 53 block it has to be a storm block which is what the one is with the "bracing" u speak of, but storm block alone don't prove it's a 53. Most storm blocks are fine. HO 24 valves don't have a crank ring, only cam sensor, non HO have both, for dodge application at least. I've never seen any 5.9 cummins have anything other than 4 damper bolts. What fuel system does this thing have? Does it actually have a mechanical lift pump in the block? It must be newer than a dodge VP engine if the lift pump hole is toward the front. Thatis how a common rail dodge is and it is because they r using the same block they would use for an industrial rear gear train application. In that application the injection pump would block the lift pump port if it were closer to the back.
But u shoul definitely keep Ur 12 valve around. That is a good engine all around.
Oh, and
Last edited by welderboy250; Apr 14, 2012 at 08:27 PM. Reason: Automerged Doublepost
Old Apr 14, 2012 | 09:58 PM
Fire Power's Avatar
LOL
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
