leaky injector
Old Apr 12, 2012 | 03:28 PM
9512valve's Avatar
Default leaky injector
so ive fixed about every problem except now i have a new one. 1 injector leaks out of where it sits in the block. im hoping its just an O ring. but any ideas what it could be
Old Apr 13, 2012 | 09:22 AM
ricet07's Avatar
Torque the retainer nut down to spec. it might have worked loose a little. The o-rings are more of a dust ring and the seal is the copper washer that sits between the injector and head. Make sure its not the return line horseshoe washers and it could be leaking down from there.
Old Apr 13, 2012 | 01:56 PM
SCHMITTY's Avatar
The little banjo bolts that hold my return line where leaking and I thought it was the injectors leaking. I was able to get almost a quarter turn tighter on the little banjo bolts.
Old Apr 14, 2012 | 08:30 PM
9512valve's Avatar
ill have to check that out been raining alot and no garage.
Old Apr 14, 2012 | 08:41 PM
ricet07's Avatar
Just spray some brake cleaner on them and them with some air and watch for the leak. Good luck!
lowride
Oct 24, 2015 08:50 AM
Jun 8, 2015 07:10 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
