6.0 bullet proof
Old Apr 12, 2012 | 11:22 AM
bigred91's Avatar
Default 6.0 bullet proof
i know that theres probably tons of threads about this already but i am just looking to see what the average cost would be to have an mkm customs master solution for my 6.0. i just want to know around what labor times and additional osts would be or if anyone has anybetter suggestions to save money. heres what the Kit Includes:
•EGR Delete Kit by Sinister Mfg. Company
•Black Onyx Head Gaskets either 18mm or 20mm by Sinister Mfg. Company
•Ford Factory Exhaust Gaskets
•ARP Head Stud Set
•Ford Factory Oil Cooler Kit
•Ford Factory Oil Cooler Screen
•Ford Factory Intake Gaskets
•Ford Factory Turbo Hardware/O-Ring Kit
•Ford Factory Valve Cover Gaskets
•Valve Cover Grommets
•Valve Stem Seals
•Injector O-Ring Gasket Kit
•Air Pump Gaskets
•Air Sensor Gaskets
•Cylinder Head Gaskets
•Cylinder Head Plugs
•Fuel Filter Gasket
•Fuel Filter O-Rings
•Fuel Pressure Regulator Gaskets
•Oil Filter Gaskets
•Oil Pump Cover Gaskets
•Oil Pump Inlet Gaskets
•Oil Pump O-Rings
•Throttle Body Gaskets
heres a link to the site MKM Complete Master Solution Kit for 6.0L Powerstroke (Sinister EGR Delete, ARP Studs, Gaskets, Oil Cooler)
all help is appreciated
Old Apr 12, 2012 | 11:26 AM
Powerstroking814's Avatar
Do not use the black onyx head gaskets... Go with for oem
Old Apr 12, 2012 | 12:01 PM
bigred91's Avatar
SOkay they have the same kit with oem gaskets. Does everything else look good though?
Old Apr 12, 2012 | 10:45 PM
bobfbigman's Avatar
Don't know if that is such a great deal, I bought all parts from Tousley Ford and ARP studs off Ebay /they were $408 and the parts from Yousley were around $750, which included, 2 head gasket,oil cooler, 8 oring kits for injectors, new dummyplug set, updated fuel spring,and bought exhaust manifolg gaskets were bought at local dealer along with intake gaskets. I bet they charge you alot to upgrade from Black Ox gaskets to the Ford ones which are better.
Old Apr 13, 2012 | 12:38 AM
jeffa6980's Avatar
you could probably get everything for under 1500 bucks if you shopped around but if you just dont want to shop around or just get everything from one place go ahead. Add about 500 to 600 bucks for the heads to be checked. Are you doing this work yourself or getting someone to do it for you?
Old Apr 13, 2012 | 07:16 AM
HeavyAssault's Avatar
It can be done for cheaper....shop around. Does anyone know where the Throttle Body Gaskets go??
Old Apr 13, 2012 | 09:58 AM
bigred91's Avatar
I may get my dads mechanic to help me do it if hes up for it and if not then ill have a shop do it. Theres a shop down the road from me that does a complete bulletproof for $5200 out the door. Is that a fair price?
Old Apr 13, 2012 | 01:20 PM
bobfbigman's Avatar
Its a shame you aren't closer, I could cut that in half.
mfr63
Sep 20, 2015 05:27 AM
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
GHETTO_PIZZA
Apr 9, 2015 10:48 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
