2005 F350 6.0L Powerstroke No start
Old Apr 11, 2012 | 06:30 PM
haytham's Avatar
Default 2005 F350 6.0L Powerstroke No start
Hi All
I have a 2005 f350 that cranks but not starting. Batteries are good, starter is good. Oil level is fine. Tested my FICM with key on 47.7V with engine cranking 47.8V. I scanned with an OBDII I got the following codes p0261,64,67,70,73,76,79
I have no idea whats going on or where to start
any help is highly appreciated
thanks
Haytham
Old Apr 11, 2012 | 06:59 PM
Powerstroking814's Avatar
Those are all injector codes... Are you getting any smoke while cranking it?
When you turn the key on can you hear the injectors buzzing? Can you hear your fuel pump priming?
Is it cold out where your located?
Check your connections to your ficm...
Last edited by Powerstroking814; Apr 11, 2012 at 06:59 PM. Reason: Automerged Doublepost
Old Apr 11, 2012 | 07:02 PM
haytham's Avatar
thanks for the reply
no smoke when trying to start, but I can hear the injector buzzing and the fuel pump priming.
sorry, I am in Calgary, Alberta and it was +10 today
Old Apr 11, 2012 | 07:08 PM
Ok no smoke so your not getting fuel... Just curious, you sure your hearing the injectors and not the vacuum pump?
Old Apr 11, 2012 | 07:12 PM
haytham's Avatar
not 100% sure! Is there anything I can do to 100% sure. thanks for your help
Old Apr 11, 2012 | 07:36 PM
Your welcome
Really need to get it hooked up to a scanner to check a few things...
It could be your ipr ( injector pressure regulator), hpop ( high pressure Oil pump), oil leak in the high pressure system, or injector o-ring
Last edited by Powerstroking814; Apr 11, 2012 at 07:36 PM. Reason: Automerged Doublepost
Old Apr 11, 2012 | 07:47 PM
haytham's Avatar
maybe i should have the truck towed to the dealer then. thanks for all the help again
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
makuloco2000
Feb 15, 2015 02:31 PM
smbenoit_79
Feb 2, 2015 01:35 PM
makuloco2000
Oct 27, 2014 10:40 PM
