Emergency brake problem....
Old Apr 11, 2012 | 12:36 PM
Dieselfan2500's Avatar
Default Emergency brake problem....
I have an 01.5 cummins and the emergency brake will not hold at all! I've turned the adjustment bolt all the way and the rear brakes are good, anyone have any ideas for me???
Old Apr 11, 2012 | 07:58 PM
wyodiesel92's Avatar
Adjust them at the rear end if your pedal is creating tension with the pedal down
Old Apr 11, 2012 | 08:06 PM
How do I adjust them at the brakes themselves? Never adjusted rear disk brakes before, only changed the pads. Thanks for the feed back
Old Apr 12, 2012 | 07:05 PM
dolla_hite's Avatar
sounds like your e brake shoes are worn. the e brake shoes are different from rear brake pads.
Old Apr 13, 2012 | 11:21 AM
1AMatt's Avatar
Site Sponsor - 1aauto
BINGO!! Your emergency brake is inside the rear rotor. It's a mini drum set up
Old Apr 13, 2012 | 12:29 PM
Aha! Is it a pain in the a$$ to change those pads? Thanks a lot guys you really helped me on that bc I had no clue there was drums inside the rotors!
Old Apr 13, 2012 | 10:51 PM
Not bad, but to adjust them if they are good you'll just have to crank on the star wheel from the back side. The way your supposed to do it is to jack it up, tighten the wheel until you can't turn the tire then back it off just far enough that it drags slightly. I prefer to if I have the wheels of to make slight adjustments to tighten and test fit until turning the rotor/ drum I get the slight drag. going in from the back side I think is a pain.
Old Apr 14, 2012 | 11:55 AM
Alright, sounds good thanks everyone for the information!
Old Apr 14, 2012 | 09:56 PM
Top tip for doing shoes too, do one side at a time so you have the other completed side to compare to and use to figure out how it all goes together
Old Apr 15, 2012 | 06:18 PM
dolla_hite's Avatar
dont you have to pull the axles out to changes the e brake shoes?
