Boost - How Much
Old Feb 8, 2008 | 05:46 PM
Wyatt Earp's Avatar
Default Boost - How Much
Hi,
Question: How much boost can one (or should one) get out of a stock turbo and charger?
I'm playing this afternoon and had the smarty off but the comp on 4x5 (5x5 just smokes too much) and I managed 33 pounds completely unloaded, flat, dry, straight road. The EGT was 1200 F so I backed off.
Old Feb 8, 2008 | 09:32 PM
Benjamin's Avatar
Bombardier
you can get upwards of 45 psi out of them. how long they will last and your head gasket will last is a different story.... anything really over 35psi is just blowin' hot air.... not usable really..... 33-35 should be very comfortable for those stock turbos.....
Old Feb 8, 2008 | 09:34 PM
94cummins12v's Avatar
i found out the hard way that you dont want to excede 35PSI for very long derations
Old Feb 8, 2008 | 10:08 PM
Wyatt Earp's Avatar
Good to know.
Old Feb 8, 2008 | 10:11 PM
DangerousDuramax's Avatar
Stock Duramax is that same way. Anything after 32psi is loosing efficiency but you can spool them much higher.
Old Feb 8, 2008 | 11:05 PM
exactly when you just blowing hot air it doesnt help out at all even if its intercooled unles your like me blowing 53PSI out of a Phat shaft 62 than after about 55PSI its just wasted air and a stock head is only rated for 55PSI anyway
Old Feb 15, 2008 | 03:59 AM
Fishin2Deep4U's Avatar
Boost is only part of the issue. Gotta watch drive pressures...
Dave
Old Feb 19, 2008 | 03:45 PM
Mopar1973Man's Avatar
But back to the stock...
35 PSI for both HX35 and HY35 Turbos...
I'm turning right out at about 33-35 PSI with my Edge Comp on 5x5. My pyro can get to as high 1300 roughly...
Old Mar 4, 2008 | 11:37 AM
Horse Power's Avatar
I know some people getting 40 psi out of them with no trouble.
Old Mar 4, 2008 | 12:58 PM
Whit's Avatar
Site Mascot
on a HX35 anything past 35 psi is out of the MAP effeciency so anything above that will be very hot and only net higher EGT's
