Rear Brake Advice
Old Apr 10, 2012 | 09:12 AM
DevilDocTater's Avatar
Default Rear Brake Advice
Hello All
I have my buddies 97 4x4 dually and his back brakes wont stay adjusted and wont contribute to the braking of the truck......any advice?
Thanks
Wade
Old Apr 10, 2012 | 09:18 AM
RAW's Avatar
RAW
This isn't a solution to the drum issue, but recently I swapped to Discs. I got an axle from a wreckers, and replaced what was needed, then did the swap. I now have disc brakes in the rear, and braking has improved significantly. Not sure if that's an option, but something to think about.
Old Apr 10, 2012 | 11:54 AM
ricet07's Avatar
Mark the little adjuster star wheel and see if it moves or backs off by itself afyer driving. Is there any fluid coming from around the lines or cylinders? My guess is the cylinders are going bad.
Old Apr 10, 2012 | 12:29 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yes the adjusters could be frozen, or I believe it is a cable that automatically adjusts them. Or as stated above it could be a wheel cylinder problem as well!
Old Apr 10, 2012 | 08:27 PM
Thanks for all the replies!
Im at work (24hr shift) so im going to tear in to it tomorrow morning. worst case if i need to completely replace the rear brakes (drum,wheel cyl, shoes,adjusters,backer plate..ect) what kinda cost am i looking at?
Thanks again!
Old Apr 10, 2012 | 10:50 PM
ricet07's Avatar
You can probably get the drums turned for 10-15 bucks each if they arent horrible. Shouldnt need a back plate unless its beat all to hell and the rest shoes, cylinders and hardware will run you 50-100 depends on what shoes you want to run. Are you a corpsman by any chance??
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
