Cp3 problems
Old Apr 10, 2012 | 12:55 AM
Justin05's Avatar
Default Cp3 problems
Need some expert advice again fellas my 05 cummins gave me another fit yesterday I put the industrial injection bop on the cp3 ( what a local mec told me I needed to get rid of a code I was getting p1223) and I hauled hay for about 4 hours with my tuner on stage 3 and had no problems but when I drove to work it blew 2 freeze plugs out of the pump one behind the fca and on on the bottom of the pump and started leakin fuel my question is what caused it to do that and it has a squeal at about 1300 ( sounds like a belt squeal but removed the belt and it still does it) what would be a good replacement for it or do yall think it done internal damage to the motor no fuel got in the engine thanks in advance for all the help
The truck has stock injectors
Old Apr 10, 2012 | 02:55 PM
nasty 2005's Avatar
Sounds like you didn't get the checkball put back in,but I can't believe it would last that long if that was the case!
Old Apr 10, 2012 | 03:26 PM
cummin_un_glued's Avatar
FormerVendor
^^^ what he said, i've seen that very same thing happen before and the truck made it about 15 miles before the pump blew up....time for a new pump
Old Apr 10, 2012 | 04:08 PM
Justin05's Avatar
When I was putting the bop on I put a little lube on the spring to hold the ball in place I had a rag under the pump but never saw it, where is the best place to get a new pump
Old Apr 10, 2012 | 07:03 PM
FormerVendor
so take it back out and see if the ball is still there, i can get ya a few different pumps
Old Apr 10, 2012 | 07:26 PM
Justin05's Avatar
I'm sure the pump is junk it makes noise now what pump would you recommend having just a tuner on it
Old Apr 10, 2012 | 09:06 PM
FormerVendor
stock pumps are good for up to 500hp so that all depends on your overall hp goal
Old Apr 11, 2012 | 03:46 AM
Justin05's Avatar
Would a stock pump supply enough for 90 hp injectors if I did go bigger? I don't want to go to big because of needing to pull a trailer from time to time
Old Apr 11, 2012 | 06:00 PM
FormerVendor
i have a customers truck running 90hp DDPs with a EFI Live tune that is larger then a smarty on SW9 and a silver bullet 66 and he's still running the stock CP3 with an airdog lift pump.
Old Apr 11, 2012 | 07:48 PM
Justin05's Avatar
Ok thanks for the help everyone getting a pump tomorrow
