pulled head any thoughts on rebuild or not?
Old Apr 9, 2012 | 12:46 PM
pullincrazy88's Avatar
Default pulled head any thoughts on rebuild or not?
Well i pulled the head off the engine today and am a little worried about if i should run it or not with out a rebuild. all the cylinders look pretty good except for number 3. there's some obvious signs of wear in it. there's a few wear marks on the cylinder wall but i can barley catch only 2 of them with my finger nail. and i can barley catch any of a lip at the top of the cylinder telling me there probably wasn't to much more then 100-120 thousand miles on this engine and it rotates freely no binding or play. not sure if i should have it rebuilt or if it would be fine to keep running for a long time. the blow by tube isn't all gummed up from oil it looks pretty clean.
I don't have a lot of money to do this swap right now so that's why i'm contemplating on if i need to have it rebuilt or not. any thoughts on if its okay or a ticking time bomb ready to go off right after the install
Old Apr 9, 2012 | 01:35 PM
tiremann9669's Avatar
I wouldn't rebuild unless a compression check warranted it.
Old Apr 9, 2012 | 02:25 PM
the problem is i can compression test it because the head is already off
Old Apr 9, 2012 | 04:51 PM
Yea no kiddin
Old Apr 9, 2012 | 06:26 PM
cummin_un_glued's Avatar
FormerVendor
hone it a little and it will run for a long time like that, it will just be a little low on a comp test on that cylinder
Old Apr 9, 2012 | 08:01 PM
well i decided to fully disassemble the engine and its a good thing i did. number 3 piston was definatly rubbing on the cylinder wall. not sure if i can reuse it or not gonna have to ask the local cummins guru if hes got any extra ones laying around
Old Apr 9, 2012 | 09:23 PM
FormerVendor
if he dosnt let me know i've got a few
Old Apr 10, 2012 | 12:11 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Originally Posted by pullincrazy88
well i decided to fully disassemble the engine:
Its a lot of work and coin... But not a bad idea!
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
