manual sliding window to power window
Old Apr 9, 2012 | 09:41 AM
99stackedpowerstroke's Avatar
Default manual sliding window to power window
My truck has a manual sliding rear window which sucks since its a 4door, I've been wanting to convert it to a power sliding window, has anybody done this before? Is there enought room behind the seat to mount the motor and track? I just want to do some research before I jump into it, any help would be awesome!!!
Old Apr 9, 2012 | 02:23 PM
fordbomber's Avatar
As far as i know you can buy a one piece rear window, and also purchase a kit that allows the window to go straight up and straight down, (very similar to a toyota's rear window). I havnt researched it yet but i know alot of people that have been talking about them.
Old Apr 10, 2012 | 01:24 AM
Mdub707's Avatar
I'm pretty sure the motor to move the window is already there too, just doesn't have the window to do it. I feel like I read something about this on the ORG before too. I'll look around and see what I can find.
Old Apr 10, 2012 | 09:56 AM
That would be great if you could! Cause if the motor and wires are already there that would be fantastic! Thanks in advance!
Old Apr 10, 2012 | 11:56 AM
Mdub707's Avatar
I found this, looks like nothing is there, you need to buy everything to do it, but a junkyard would be your best bet....
I have a 05 super cab and did this conversion, the rear window,cable and motor came together. I got this from a late model salvage yard. the conections were already in the truck to plug the motor in and i got a new switch for the dash as the 05 to 07 trucks use the multi function switch for the 4x4,back up sensor and the power sliding switch all in one. I bought the switch from ford and installed it and it works great. If you get the slider used from the salvage yard make sure to get the slider motor mounting bolts and blind nuts from the doner vehicle as they are not there if the truck left the factory without a power slider
Old Apr 11, 2012 | 08:01 PM
Well that just sucks!! Thanks for looking it up MDUB!!! Greatly appriciated!!
Old Apr 11, 2012 | 08:27 PM
cpalmer's Avatar
CR Laurance makes one that slides open like the fords had factory, 3 panel window, 1 in the middle opens. There are no kits for a complete drop down like the toyotas have.
May 10, 2015 10:57 PM
