code thrown need to kno what it means any help plz
Old Apr 9, 2012 | 01:55 AM
dcummins4me's Avatar
Default code thrown need to kno what it means any help plz
My check engine light came on and i need to kno what it means i checked my edge and it said that inject side 1 circuit open and it bogged on me until i took my foot off the gas and put it back on does any one kno what this could be thank u.
Old Apr 9, 2012 | 02:53 AM
1999stroker's Avatar
Sounds like an stuck injector
Strokin' Away
Old Apr 9, 2012 | 03:14 AM
how would i fix that
Old Apr 9, 2012 | 03:34 AM
Replace the bad injectors.I'm not a cummins guy but there should be a sticky at the top of your year specific truck with codes
Strokin' Away
Old Apr 9, 2012 | 03:58 AM
but the code goes away then comes back maybe 400 miles later
Old Apr 9, 2012 | 05:01 AM
It goes away by itself or after you clear it? If it comes bak after you clear it then it's telling you there's an issue. Someone will chime in with more knowledge then I on cummins motors.
Strokin' Away
Old Apr 10, 2012 | 12:28 AM
by it self i dont clear it i was told today that somthinf is wrong with the harnes that tells how much to put in on the first cylender
Old Apr 10, 2012 | 09:32 AM
bftrain's Avatar
Had the same problem on my b injector circuit. Replaced the valve cover gasket and life is good.
Old May 6, 2012 | 06:40 PM
so u think it could be a gasket??
can that also make the truvk lag and hold back fuel??
Last edited by dcummins4me; May 6, 2012 at 06:40 PM. Reason: Automerged Doublepost
Old May 6, 2012 | 06:44 PM
mysterync's Avatar
Oh my hope you don't try and fix your truck with the information in this thread. Its either a failed solenoid possibly caused by high return, a damaged harness, or a failing ecm.
You'll need to complete the injection system pinpoint test and check injector resistance and then harness resistance.
It will put you on the right direction.
Sent from my DROID BIONIC using Tapatalk 2
