4wd Light
Old Apr 8, 2012 | 11:47 PM
ricet07's Avatar
Default 4wd Light
I just put in my new clutch this weekend and after I got everything all put back together I noticed the 4wd light is on when the shift lever is in 2H position. I did have the linkage apart and transfer case off the trans to do the clutch but everything went back together the way it came apart. Anyways the truck IS in 4wd when shift lever is in 4wd position and IS in 2wd when lever is in 2H postion, why is the indicator light oposite of what it is suppose to be??
Old Apr 9, 2012 | 08:29 AM
Freerider6-9's Avatar
The indicator light runs off of the cad on the front axle. Pull the sensor and see what position it in. Is the front axle disconnecting when in 2wd? Or just the tcase?
Old Apr 9, 2012 | 10:22 AM
ricet07's Avatar
The front axle engages and disengages but the t case isn't if I'm thinking right. I jacked the front end up and in 2H the drivers side wheel spins freeley then in 4h both front wheels turn but they shouldn't turn if t case is in 4wd correct? I disconnected the sensor last night and plugged it back in, still does it though.
Old Apr 9, 2012 | 11:03 AM
94 12valve's Avatar
the vac line off the t case is not on correctly, all you need to do is pull it off and give it a 90* turn. Its the one right above the shift linkage on the t case
Old Apr 9, 2012 | 03:02 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the vacuum connector on the T case. It can very easily be put on wrong!
Old Apr 9, 2012 | 03:44 PM
ricet07's Avatar
I will give that a shot tonight, i thought it was pretty straight forward though. The vacuum line head was shaped like an arrow with 4 female ends and the male ends on the t case lined up. That is about all I can think off that would be any different from when I took it out though. Thanks guys and matt I saw your video about door panel replacement and looked on your site but could find any panels, do you carry them or know where to find a set besides ebay?
Old Apr 9, 2012 | 09:41 PM
sweetv8s10's Avatar
While we are on the subject of the 4wd light mine wont come on would this cause the my problem also?
Old Apr 10, 2012 | 11:29 AM
ricet07's Avatar
check the sensor on the front axle actuator
Yea there is only one way that vacuum head hooks up to the t case I tried rotating it but it won't go on any other way.
Old Apr 10, 2012 | 11:47 AM
Eddiebuntain's Avatar
Does the front axle engage? If not, the vacuum lines could be cracked or torn. If it engages, the sensor or light bulb could be bad, or the wiring between them may be damaged.
Old Apr 10, 2012 | 12:14 PM
1AMatt's Avatar
It could be a bad sensor/wire/connection.... Or your front axle may just not engage.
