Transmission question!
Old Apr 8, 2012 | 04:47 PM
SRTcummins's Avatar
Default Transmission question!
My trans is shifting smoother than a hot knife slicing butter...Should I be concerned? Theres no power loss in gears. 2nd and 3rd have almost no difference in rpm/gear ratio thats the only thing thats making me have second guesses. Any input would be great!
oh, and im running level 3 on edge juice for city and highway driving. (for mpg purposes)
Thanks,
Nick
Old Apr 8, 2012 | 09:02 PM
turbo2332's Avatar
did this just occur or has it always been smooth. banging gears isnt really what is good in most situation however that is what peoplethink they should feel. the frictions are designed to slip while engaging making that smooth as butter situation possible. if they are burn or glazed over you will be able to slip them under full power and your fluid will be a nasty smelling brown.
Old Apr 9, 2012 | 08:57 AM
SRTcummins's Avatar
as i add more power from the chip it shifts smoother. But you wont feel mine kick when switching gears unless your wot or giving it like 2% throttle haha
Old Apr 9, 2012 | 09:25 AM
turbo2332's Avatar
sounds like its working like it should
Old Apr 9, 2012 | 02:31 PM
empty wallet's Avatar
I completely disagree. You don't want it slipping shifts... I think you have it totally backwards
And yeah it shifts softer when you up the ante because it's slipping worse, if you turn the edge all the way up and nail it in 3rd or 4th it doesnt slip? even from low rpm's?
Old Apr 9, 2012 | 02:54 PM
turbo2332's Avatar
thats what im saying if it doesnt slip under WOT/full power and hes just worried about smooth shifts there most likely isnt anything to worry about. check your fluid that will tell you if things are slipping. and i ment just exactly what i said.
Old Apr 9, 2012 | 07:51 PM
SRTcummins's Avatar
i have done runs on level 2 from a light at wot and the trans wouldnt slip, it will flutter and feel like it hesitates but it still goes and wont slip. When i slam it in overdrive the t/c unlocks and the engine revs up. when it shifts you cant feel it, it like slides right into the next gear. i just dont want to be melting my gearset together!
Old Apr 9, 2012 | 08:13 PM
turbo2332's Avatar
your not. check the fluid just cause and if you have a stock converter it is going to let loose sooner than later. you should absolutly upgrade the converter and VB as soon as possible or you will have problems but what you discribe not is just posibly a converter with the beginning signs of the shakes involving OD.
Old Apr 9, 2012 | 08:15 PM
If it doesn't shudder or slip in the middle of gears when you get on it your fine... You wouldn't believe what my tranny has been thru
Old Apr 9, 2012 | 08:17 PM
SRTcummins's Avatar
it shakes like a bad u-joint at stops if i get on it, other than that its fine guess
The guy used to pull horse trailers for crying-out-loud. i think this tranny may be a good one *knocks on wood* haha ill use my graduation money for it
NO BIG DEAL screw college
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
Trevlar11
Dec 11, 2014 03:30 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
