ficm tested good... now im stumped...
Old Apr 7, 2012 | 04:36 PM
brondondolon's Avatar
Default ficm tested good... now im stumped...
94k miles and its slow as a dog at start up and im now getting 9.2 mpg (over head) ficm tested out good 47.x volts truck has a new hpop a new icp a ipr and icp pig tail so now im at a loss here... no check engine lights either any ideas truck is a 2003
Old Apr 7, 2012 | 05:49 PM
Powerstroking814's Avatar
We're in the same boat... I've been trying to figure it out... My next move is to get my PCM rolled back to a different strategy...
But now I got a bad gpcm...
Old Apr 8, 2012 | 09:02 PM
jimrd's Avatar
my truck was hard to start
found out the batteries were not 100 percent
changed both and ....wow ....starts up fast...what a difference
maybe you have a bad cell
one battery is bring down the other one....
I also changed to the swamps 58 volt FICM
last winter
Old Apr 8, 2012 | 09:24 PM
Mdub707's Avatar
It is amazing what poor batteries will make these trucks run like. Poor starting, poor idle, make the trans shift funny etc...
Old Apr 8, 2012 | 09:40 PM
i have 2 optima yellow tops that i just got in january so im sure the batteries are fine
i just ordered rev-x and 4 gallons of shafers full syn also i noticed my intercooler boots are really squishy and one is dripping oil i ran a scanner on my truck and my boost was at 21psi which the guy told me was low so im assuming a leak reguardless i bought some bd performance intercooler boots with t-clamps just now too i was gonna get the riffraff boots and use the stock clamps but i might as well do it right and do it once and i read good things about them. just racked up a 400 dollar bill in all but hopefully this helps
also last night i went up this mountain trail by my house and its kind of steep driving down so i didnt wanna burn up my breaks so i used 1st gear all the way down (30 min) after i got on the road it was driving kind of weird almost like it was in O/D... i only put it in 4high with the hubs locked 2 times and rompped on it a little. after i got back on the road i tried to 4wd power break it and it was taking a while to get it to 2k rpm then once it did it dropped a little so i took my foot off the throttle because i got a little scared... normally ill cherp the tires a bit this time however it took off like i was towing a trailer... any ideas?
joejack6.0
Apr 29, 2015 11:45 PM
makuloco2000
Feb 15, 2015 02:31 PM
willgoss
Ford Powerstroke 08-10 6.4L
Feb 12, 2015 09:52 PM
Jackson Gregory Scott
Nov 1, 2014 04:06 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
