Pinion Seal
Old Feb 7, 2008 | 10:29 PM
94cummins12v's Avatar
Default Pinion Seal
ok i have a dana 80 rearend and my pinion seal is leaking do i have to remove the pinion completely by terring the whole rearend apart or can i just pull the seal. ive pulled a dana 70 apart back in september so it wont be that hard just time consuming, just wondering if i could pull the joke and then just the seal
Old Feb 14, 2008 | 07:54 PM
EMD567's Avatar
Yessir, Pull the yoke and pry that seal outta there.
Good luck
Old Feb 14, 2008 | 08:00 PM
toy4xchris's Avatar
yup x2 that should be all ya gotta do just make sure you clean it all out good.
Old Feb 15, 2008 | 12:06 AM
ok cool i was afraid i would have to pull the pinion
Old Feb 15, 2008 | 12:23 AM
LOGANSTANFORTH's Avatar
most if not all trucks you can pull just the yoke to change the seal.....
Old Feb 17, 2008 | 11:53 AM
saab9k's Avatar
If it was my truck, I would also install a speedy sleeve on shaft where seal goes.
There is no way to effectively polish that area with shaft in truck.
Old Feb 17, 2008 | 08:43 PM
whats that do
Old Feb 22, 2008 | 03:32 AM
NMCUMMINS's Avatar
basically you install a sleeve over where the seal surface rides on, so it has a nice new surface to seal against.
Most oils seals will wear a groove in the suface of what ever they seal against, and if you don't either polish this out or install a sleeve, alot of the time the new seal won't seal properly.
Old Feb 22, 2008 | 11:33 AM
513yj's Avatar
make sure to torque the nut afterwards. the most thorough way is to pull the carrier and torque the nut, check the preload and then put the carrier back in and check all that junk too. but i never do that unless i am replacing the r&p. it's kinda like flushing the radiator or checking tire pressure every month, supposed to but never do.
Old Feb 22, 2008 | 02:45 PM
im not going to pull the whole rearend apart it was rebuilt 10,000 miles ago befor i bought it
makuloco2000
Dec 20, 2015 11:19 PM
yfzrunner
Sep 17, 2015 05:23 AM
realtrucksrattle
Jul 30, 2015 12:05 PM
wildbill
Jan 31, 2015 11:14 AM
