short block, head and pump weight
Old Apr 6, 2012 | 03:49 PM
smedley's Avatar
Default short block, head and pump weight
What do these weigh individually? My engine stand has a 750lb weight limit and was wondering what I can can put on the short block before I put it into the truck.
Old Apr 6, 2012 | 10:10 PM
ricet07's Avatar
They are 975 with head and everything. Dry with everything 905.
Old Apr 7, 2012 | 10:48 AM
smedley's Avatar
Do you know how much with head and pump? I can put on. Al the front accessories while its in the truck.
Old Apr 7, 2012 | 12:00 PM
ricet07's Avatar
Sorry thats what I meant the long block (with head and pump) is 975. Not sure what a short block weighs off the top of my head. I have seen alot of home made setups and most guys are using 1000lb or 2000lb stands. I would maybe put a short block on a 750 stand but wouldnt do much work on it while its on there because it will get to bouncin.
Old Apr 7, 2012 | 01:41 PM
smedley's Avatar
Haha ok thanks. I just do t want the motor hitting the ground.
Old Apr 7, 2012 | 03:02 PM
tower_ofpower's Avatar
Mount the engine sideways rather than from flywheel housing up. Alot easier to hold weight closer to the supports than
Hangin away from it.
Old Apr 8, 2012 | 01:51 PM
SCHMITTY's Avatar
How do you mount the engine sideways? Do you mean on a typical 750 lb engine stand?
Old Apr 8, 2012 | 10:32 PM
You'd probably have to do some modifications to the mount or make your own. How much extra change do you have to work with? I bought a 1 ton stand for like $150 from summit some years back.
Old Apr 8, 2012 | 11:34 PM
ricet07's Avatar
Harbor Freight has a 1 ton stand on sale for 130 right now.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
RatsMC
May 4, 2015 05:25 PM
