Factory CAT Questions
Old Feb 7, 2008 | 06:14 PM
magram's Avatar
Default Factory CAT Questions
I have a piece of 4" exhaust pipe, what size is our factory exhaust? I measured the tailpie and its 4" but it looks like it flares out, is our factory exhaust only 3"?
If I cut the cat out will the 4" Piece of pipe I have work? What other precautions do I need to take? Do I need to unhook my batteries before hand? Will it through a code if I don't?
Thanks!!
2007 5.9l cummins.
anyone??
Old Feb 7, 2008 | 08:17 PM
94cummins12v's Avatar
for working on the exhaust they recomend you do disconect the battarys but i never did while puting my stacks on, also the stock exhaust is 3" from turbo down into a four inch tip. if you have a 4" pipe already it will not work it is to big, unless you buy two bell reducers from 4" to 3" but i recomend buying a new 3" pipe to replace it. Also on mine i have the stock down pipe into 5" flex tubing all the way to my stacks
Old Feb 7, 2008 | 08:18 PM
2001shrtbedcummins's Avatar
sorry but that's not entirely correct, as of the 600 models, they came with factor 4 inch exhaust.
Old Feb 7, 2008 | 08:28 PM
the best way to find out is to measure the pipe and go from there
Old Feb 7, 2008 | 08:31 PM
indeed it is. I know my 04.5 so doesn't have a "tip" it's 4 inch all the way to the tailpipe, then again I don't have a cat either.
Old Feb 7, 2008 | 08:34 PM
i took both the cat and muffler out of mine and ram 5" flex all the way to my stacks
Old Feb 7, 2008 | 08:36 PM
was yours a cali truck? I have a resonator...but not kitty
Old Feb 7, 2008 | 08:39 PM
no made in michigan but stayed in idaho ever since
Old Feb 7, 2008 | 08:49 PM
that's strange...
Old Feb 7, 2008 | 09:00 PM
why is that strange
