Getting mod ideas
Old Apr 3, 2012 | 05:25 PM
6btf350cummins's Avatar
Default Getting mod ideas
I have looked over the forums pretty well and am going to start planning my "vacation time" week off work into modding my truck a bit.
93 motor in 87 F350 intercooler is hooked up already & killer dowel pin has been fixed
Goal 400 HP budget.... Economicly challenged
so Far I have
1 set up pyrometer
2 fix speedometer
3 tune pump (read and printed the manual)
4 change gear ratio
5 work on interior
Any other input/suggestions would be great
Old Apr 3, 2012 | 07:24 PM
jdbigblue12v's Avatar
injectors, intercooler from 1999-2003 powerstroke, bigger injectors and maybe a hx35/hx40 hybrid turbo
Old Apr 3, 2012 | 11:42 PM
1stgenblowingsmoke's Avatar
Timing bump.
Old Apr 4, 2012 | 06:02 AM
I am still new to this so can I get some clairification on a few of those suggestions.
What benefit does the intercooler suggest off a powerstroke offer me that my dodge one doesn't, or do better than my dodge one?
Timing pump, injector pump. Am I mistaken or are they the same thing?
@ jdbigblue12v. What kind of prices shouls I expect with injectors? I know I will read about them types and sizes before I do it though. Also. Price range on that turbo?
Old Apr 4, 2012 | 01:24 PM
the powerstroke intercooler is better flowing and is larger for about 100$ you can go wrong. no such thing as a timing pump. the injection pump is mechanical wich you can advance the timing of the pump by 1/8th and gain a few lbs of torque. if you want to do new injectors i would also suggest a turbo or do a GDS 60mm upgrade and do 5x.12 injectors but not sure if you will need a bigger turbo but you most likely will need atleast an hx40
Upgrade Compressor Housing & Wheel combo (58mm inducer) for 1991.5-1994 Turbochargers
Old Apr 4, 2012 | 01:47 PM
363coupe
Nov 4, 2015 09:41 AM
coal_life
Aug 26, 2015 07:50 PM
Duramax2323
Chevy/GMC Duramax 01-04 LB7
Mar 9, 2015 04:34 PM
UniqueCopy
Dec 14, 2014 11:37 AM
txbiker
Jeep Liberty
Oct 27, 2014 10:36 AM
