waste gate??
Old Apr 2, 2012 | 07:11 PM
blacksmoke82's Avatar
Default waste gate??
ok im going to try this one more time.. i have all the parts needed to run a triple turbo set up but im not sure which turbos should be gated if any. two small s359 for the top an a s366 on bottom none of which are gated what happens if theres no gate? should the top ones have gates? any input to help me understand this would be great
Old Apr 2, 2012 | 08:51 PM
turbo2332's Avatar
why such small chargers? 1 needs to be gated 2 should be gated and 3 is fine. why not run the 59mm over the 66mm? what are you planning on gaining running 2 of the same size turbos?
Old Apr 2, 2012 | 09:07 PM
thats how it waas set up when i got them but over a super b special that was gated. my thought was the 2 small 59 s over the 66 but i just cant figure out the waste gate thing. none of the 3 are gated
Old Apr 2, 2012 | 09:38 PM
turbo2332's Avatar
th 2 59's will never come into boost if you are going to run them parellel then into a 66. meaning 3 cyl to one 3 cyl to the other. it wont ever boost till the 66 catches up!
Old Apr 2, 2012 | 10:00 PM
welderboy250's Avatar
U put the 66 on the manifold then split the exhaust into the parallel 59's which then create the "atmosphere" for the 66
IMHO u don't need a gate for the 59's but u prob do for the 66. Reason being, I don't think u will have enough exhaust flow to spin them too fast but the only way the 66 won't over boost without a gate is if u don't have enough fuel to turn it in the first place and/or the housing is so big it won't turn that fast
Last edited by welderboy250; Apr 2, 2012 at 10:00 PM. Reason: Automerged Doublepost
Old Apr 3, 2012 | 05:52 AM
turbo2332's Avatar
thank you for the clerification. but still the damn thing will be a lathargic PIG coming into boost.
so... in this setup the 66 is going to be over your small chargers? wouldnt it make more sence to have to much smaller turbos under it. like smaller than stock...?
the 66 would be the one that needs the wastegate and the 59's are fine as welderboy stated you prolly wont have enough flow to ever damage them
Old Apr 3, 2012 | 01:10 PM
i was told they should make almost instant boost. the hot pipe splits the exhaust for the 59 s. this is why im askin cause sometimes this **** boggles my mind.. the 66 is a 66-74-.91 if i remember right
Old Apr 3, 2012 | 03:20 PM
turbo2332's Avatar
i really really think the guy that told you they would make instant boost is full of ****. hell 1 hx35 doesnt make instant boost all by itself. however i have never ran such a system, this idea just absolutly doesnt sound functional to me.
Old Apr 3, 2012 | 03:47 PM
tower_ofpower's Avatar
All tripples I've seen have two large identical chargers in parallel pushing into a small "high pressure" turbo on
The manifold, doubling volume rather than say the time and a half increase of a typical compound set up all while keeping the same responsiveness. Sounds to me you've got it in reverse. Two small; one large.
Old Apr 4, 2012 | 02:50 PM
93_Fummins's Avatar
I've been reading a lot on compound setups lately, but triples still baffle me a little. From what I've seen, "most" triple setups have fairly similarily sized turbos all the way around since the CFM is going to be doubled on the split atmospheric chargers anyway. Given the split chargers are in the 59 range, I almost wonder if it would be more benifitial to run a well gated 60 or 62 as the "high pressure" charger...
