pulling motor
Old Apr 2, 2012 | 05:38 PM
smedley's Avatar
Default pulling motor
i have tried using the search and cant get any info to come up. can i pull the motor with just removing the intercooler and radiator? i have a leveler on my picker so i can tilt the motor.
Old Apr 2, 2012 | 09:13 PM
cummin_un_glued's Avatar
FormerVendor
IC RAD A/C and everything else up front also take the #5 & #6 rockers and pushrods out that will give you alot more clearance, and i take the head lifting bracket off and put just a bolt thru the chain in the hole, it gives you more room on the firewall, also while your under it dont forget the fuel lines at the frame.
12v's are very easy to pull, we pulled one a couple weeks ago and had it on the engine stand in less then a hour and a half
Old Apr 2, 2012 | 09:17 PM
12vRambo's Avatar
Quick question... Are they supposed to have so many wires under the hood? Being mechanical engines you wouldn't think so but my engine compartment seems to be a cluster F*** Not looking forward to tearing my truck apart for a paint job because I'll be chasing wires for days trying to de-clutter....
Old Apr 2, 2012 | 09:29 PM
FormerVendor
they have ECT, MAP, CPS, TPS, fuel shut off, heater grid, fuel heater, starter, ALT and A/C wiring so basicly even tho its a mechanical engine all the other parts bolted to it are not and neither is the dash, but it only takes a few min to unwire and just lay it all off the side
Old Apr 3, 2012 | 10:29 AM
smedley's Avatar
Ok thanks. The head is already off but it will be on when the motor goes back in
Shun70
Sep 20, 2015 10:52 PM
Chriscarlson
Feb 16, 2015 07:57 AM
woodsmen
Diesel Engine Conversions
Feb 9, 2015 08:37 AM
Dec 3, 2014 09:40 AM
Nov 19, 2014 01:40 AM
