Speedo acting up
Old Apr 3, 2012 | 05:31 AM
98 Cummins's Avatar
Default Speedo acting up
Hey,
My speedo is acting up. it flickers up and down.
On the weekend my rear brake on the passeger side started to lock up a bit when you are almost stopped. I haven't had time to take it a part to see what's up, but then it was fine this morning. On my way home my ABS and Parking lights came on. That's when I noticed that the speedo flickered up and down.
I will pull the drum and see what's causing the wheel to lock tomorrow night.
Would this be caused but the ABS warning?
Thanks
This morning on my way into work, I tilted the steering wheel up so I could keep an eye on the speedo, no ABS light on, and the speedo was fine, But I noticed that some lights flickered in the dash when I moved the steering wheel. So I tilted up and down, and the motor cut out and died. Shifted to neutral, and tilted the steering wheel again, and I was able to fire it up and keep going as nothing happened.
Now that I know that the problem is in the steering column, would it be the clock spring causing this or would it be the wiring harness in the steering column?
Thanks
Old Apr 23, 2012 | 11:48 AM
chen's Avatar
i had the same proplem with mine it was just a loose wire in the harness
Old Apr 26, 2012 | 11:15 AM
a24vc's Avatar
typically the sensor on the top of your rear axel will cause the ABS and Brake light to come on. And yes it will be intermitent
Old Apr 27, 2012 | 05:51 AM
98 Cummins's Avatar
Just changed the sensor, everything is back to normal.
It's a wheel speed sensor, as well as the ABS sensor.
Thanks
Corbin
Old Apr 30, 2012 | 02:29 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on that sensor in the rear end. A lot of the time it is as simple as a dirty/bad connection!
Cutlass26
Mar 22, 2015 05:46 PM
iamgizmo
Feb 6, 2015 08:48 PM
wood2turn
Chevy/GMC Duramax 04.5-05 LLY
Jan 1, 2015 07:28 PM
longcarbine
Nov 13, 2014 11:33 PM
jcottonoir
Oct 7, 2014 08:04 AM
