injectors
Old Apr 2, 2012 | 10:08 AM
cummins270's Avatar
Default injectors
Hey I'm looking at a set of 7x.016 sac injectors from j l machine has anyone ever heard of them or use their injectors?
Old Apr 3, 2012 | 07:35 PM
empty wallet's Avatar
Do you have compound turbos or a 66 single? that's a lot of fuel...
Old Apr 4, 2012 | 10:06 AM
cummins270's Avatar
No just a 62/74 with a stage three cam but I plan on running an s475 cut down to a 2.6 in the future so that's the reason I'm going so big. But I heard jl has edm nozzels for scheid and some other big brands before.
Old Apr 4, 2012 | 05:45 PM
red_rattlered's Avatar
DO NOT GO OVER .014 ON A 7 HOLE NOZZLE!
Honestly .014 is a little large for the 7 hole VCO. I would look into 6 holes if you really think you need that much fuel 6X.016 or 6.018.
Old Apr 4, 2012 | 09:24 PM
cummins270's Avatar
I've heard the 7 holes are better for the street and these are sac's not vco's
Old Apr 4, 2012 | 11:36 PM
7 holes are much more controllable on the street. Also the VCO and Micro blind SAC type nozzle are prone to cracking over .014. If your dead set on anything bigger than that I would look at 6 holes. Honestly a good set of 7X0.012 or 7X0.014s should do just fine.
Old Apr 5, 2012 | 10:51 AM
cummins270's Avatar
Well I already ordered the 7x.016's a few days ago... I know the six holes are better but I got a really good deal on these, and I was told that since they are sac's that they hold up better then the vco's. But if one does start to crack is there any warning signs before it falls off and hits a piston?? I've seen where people have said it will start to make a popping noise and they stopped driving it and replaced the tip. And one more reason I just went ahead with the seven hole is that some sled pullers I talked to said that they use 7x.020's and run fine.
Old Apr 5, 2012 | 09:03 PM
White smoke will be a dead give away.
If you dont mind me asking did you get them straight thru JL? Or a dealer?
Old Apr 5, 2012 | 11:31 PM
cummins270's Avatar
I got them from a dealer. I still had my stock injectors so I just bought the nozzels and they are gonna install and pop test them for me.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
