borg warner s360sx or s362sx
Old Apr 1, 2012 | 12:55 PM
01ram2500's Avatar
Default borg warner s360sx or s362sx
I dont know much about turbos, just want to ask some questions . A guy I know has a couple of turbos for sale , one is a s360sx with an A/R of .91 will this work on my truck , im getting ready to put 150 hp sticks in my truck , I also know that i have to get an adapter to go from a T-3 to a T-4 flange. The other turbo is a sx362sx with a A/R .91 , all your help would great
sorry guys this post needs to be in the 24v section
Old Apr 4, 2012 | 05:36 PM
red_rattlered's Avatar
Im not really sure where your getting the "sx" from.
However im going to take a stab at this. An S360 is any S300 frame 60mm turbo. The fact that you say it has a .91 A/R turbin housing means its most likely a T4 and most likely a box unit Borg turbo. My guess is a 60/68 T4 .91 charger. Honestly not a bad charger for daily driving and towing.
The S362 on the other hand im not sure about. 62mm wheel is not a true box unit borg warner wheel. Im going to guess its actually a 63mm wheel only because you state it has the .91 A/R housing. In most cases with a charger thats listed with a 62 mm wheel you dont see the .91 housing you usually see a .70 or .80 T3. My guess is its a 63/68 T4. Good way to confirm this is to look at the compressor housing if its a "3rd gen style" front cover then its most likely a box unit charger.
Remember that the .91 T4 housings are not gated.
These turbos usually retail for 750.00 new
Old Apr 4, 2012 | 07:09 PM
01ram2500's Avatar
I have been looking around the s300sx is a high performance version , and the turbine side is made from 713 inconel whith can withstand very high heat
Old Apr 4, 2012 | 11:39 PM
How much is he wanting for these turbos? I ran a box unit 66/74 T4 .91 all of last season with no issue. And im not the easiest on turbos.
