Broken egr bolt on exhaust manifold
Old Mar 31, 2012 | 09:53 PM
bigdeck33's Avatar
Default Broken egr bolt on exhaust manifold
I was doing the egr removal for my 96 cummins 12v when I broke one of the bolts that holds the egr pipe on the exhaust manifold. Now I have a broken bolt on the manifold and a 1 inch hole where the egr pipe sat. Does anybody know how to fix this permanently with out taking the manifold out, drilling out that broke bolt and rethreading it. I am okay with that broken bolt because it broke off flush with the manifold. I just want to plug that 1 inch egr pipe hole permanently. Would I be able to weld a steel plate on the cast manifold or could I thread that 1 inch hole and run a short bolt down it? Pretty frustrated so any help would be great!
DROID razr
Old Mar 31, 2012 | 10:03 PM
wildbill's Avatar
Thread it and bolt it.
Old Mar 31, 2012 | 10:12 PM
bigdeck33's Avatar
I should tap the 1 inch egr hole and run a bolt down it
DROID razr
Old Mar 31, 2012 | 10:14 PM
dezzrats's Avatar
Make sure you get any metal particles out, you don't want that crap going through your turbo. I would be tempted to take off the turbo and start it for a couple of seconds to blow it out. Get some ear plugs!
Dame smog stuff fights all the way to the end.
Old Apr 1, 2012 | 01:39 PM
bigdeck33's Avatar
Do you guys know how much pressure is inside the manifold. I got a cap on it just wondering if it will blow off?
DROID razr
Old Apr 1, 2012 | 06:58 PM
bigdeck33's Avatar
I ended up tapping that hole which is only 11/16 and threading a short pipe plug in it. The threads were pretty shallow but it threaded in there nice and tight and so far its holding up! Thanx guys form the input!!
DROID razr
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
