School me on Turbos !!
Old Mar 30, 2012 | 01:47 PM
FirehouseSmoker's Avatar
Default School me on Turbos !!
~ Looking to be Schooled on Turbos ~
Okay, well I thought I knew a little about turbos. Then, the more I searched and read about them, I found out I didn't know enough. I just ordered 2pc. Exhaust Manifold and was thinking of upgrading my Turbo while in there, but dont know what I have on my STOCK 06 Dodge 3500 Mega 4x4. Lets start...
1) When they say t4 or t3, what does this mean ? Does this mean the ports on where it mounts to the manifold or just simply mount options ?
2) What Turbo (brand) comes stock on a 06 Dodge 3500 Mega ? What (mm) impeller are stock to know what to upgrade ,too ? Any input ?
3) One or Divided ? What does this mean and which should I go with ?
Any help and input is appreciated...
Old Mar 30, 2012 | 03:36 PM
H.R.D's Avatar
1) see picture below....
2) Holset HE351CW I believe
3) One big housing vs a divided housing. Divided should spool quicker. Also it is recommended to use a divided manifold with a divided hosing and not to mix and match. (see pic below)
Attached Thumbnails School me on Turbos !!-t3-t4.jpg   School me on Turbos !!-turbo-hosings.jpg   School me on Turbos !!-divided_turbine_enlarged.jpg
Old Mar 30, 2012 | 03:54 PM
EasternAggie's Avatar
2) The he351cw has a 60mm compressor wheel, if I am not mistaken. How much fuel are you running? Tuning? Injectors? You need to match your turbo to your fueling.
Old Apr 1, 2012 | 05:37 PM
Thanks H.R.D.! That info is what I was looking for. As far as gauges go, the truck has none for Boost, Fuel/Air, ect., but they are on the way. Truck was stock when I bought it used, but after a few Mods, it will be a pretty nice truck. Thanks for your input
Old Apr 1, 2012 | 08:03 PM
H.R.D's Avatar
Glad to help my friend.
Old Apr 1, 2012 | 08:35 PM
K80's Avatar
K80
Your he351 measures 60/60/ with a 9cm housing.
Old Apr 2, 2012 | 01:49 PM
CHEMMINS's Avatar
Actual is 60/58/9cm
Old Apr 2, 2012 | 01:59 PM
Either way, we still need to know what he has done/plans to do on fueling to determine what size he needs to upgrade to.
Old Apr 4, 2012 | 01:23 PM
K80's Avatar
K80
Originally Posted by CHEMMINS
Actual is 60/58/9cm
Whats 2mm between friends? Haha
Old Apr 4, 2012 | 01:34 PM
CHEMMINS's Avatar
My wife said 2mm was a lot.......
