Code P1721 & P1720
Old Mar 30, 2012 | 08:36 AM
MattHugh's Avatar
Default Code P1721 & P1720
I've got a 2001 duramax with the allison. i was getting on it. It was fine till an hour after i got back in the truck. More than half throttle through 2-3 it kicked to neutral. After i came to a stop from limp mode it threw code P1721 for the trim solenoid B. every now and then it throws p1720 for the A solenoid. It does it every time i drive it more than half throttle. I dropped the pan. no excessive clutch material. the solenoids tested good along with the other ones. and now it WONT MOVE AT ALL. What is wrong? I need help bad this is the only truck i have to pull whith.
Old May 15, 2012 | 04:47 PM
MattHugh's Avatar
The fix 18 days at the dealership. replaced valve body. the problem internal valve body-trim pressure circuit b bore and valve worn out and damanged. The cost $2048.79 parts and labor
Old May 23, 2012 | 06:34 PM
MRaynor's Avatar
Thanks for the update, hopefully this will help out someone else.
Old May 24, 2012 | 01:13 AM
2004LB7's Avatar
for about 30% more you could have got yourself an upgraded transmission. sucks that it cost that much. thats why i dont like the dealers
Old May 24, 2012 | 05:56 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Ugh that blows You totally could have had a pretty damn well built trans for a little more
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
