New headlight or polish?
Old Mar 29, 2012 | 06:31 PM
PalmB's Avatar
Default New headlight or polish?
I have a 2001 Dodge 2500 and the head lights are real faded. Has anyone tried polishing the lens or is it better to just replace them? Any tips?
Old Mar 29, 2012 | 07:57 PM
tiremann9669's Avatar
They make polishing kits now but before that I had pretty good luck wet sanding with 600 grit and then using mothers metal polish with a little buffing wheel on a die grinder.
Old Mar 29, 2012 | 08:38 PM
Russ Roth's Avatar
I replaced one of mine yesterday and polished it with fine paint cutting compound, followed by polishing compound and waxing. Came out so well with little work that I did the other side also. Look like new but I have not yet driven after dark so can't give an idea how much it helps on lighting.
Old Mar 29, 2012 | 11:27 PM
panzer's Avatar
https://www.dieselbombers.com/diesel...storation.html
This might help you out
Old Mar 30, 2012 | 01:37 AM
DieselFueledFarmboy's Avatar
I have tried several things but the best thing as far as a permanent fix that I recently did to my 98 was to sand with 1000 grit sandpaper and clean them well, then spray with clear enamel.. Mine look like new and I will not have to re-polish them frequently
Old Mar 30, 2012 | 05:34 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
I used the 3M headlight restore kit on my Ram... AMAZING!!! Worth every penny! They looked brand new! Did the fog light too... Wax the crap out of them after though.
Old Mar 30, 2012 | 07:48 PM
PalmB's Avatar
i heard of the 3M kit. why did you have to wax them after? my headlights are terrible, the fog lights are ok and the trun signals are perfect. i dont know if they were replaced. how about for really bright headlights... change the bulbs? suggestions on brands or types?
what is clear enamel? like a clear spray paint?
Old Mar 31, 2012 | 09:29 AM
ebbtide357's Avatar
i also used the 3m kit and was amazed it comes with all you need i was ready to buy new headlights and said might as well try it did the fog lights to they came out like brand new worth a shot
Old Apr 1, 2012 | 01:42 AM
Waxing them helps protect them. However... as stated above you could probably clear coat them for better effect maybe?
Old Apr 1, 2012 | 07:55 AM
scottywiest's Avatar
i polished mine many times then i tried regular colegate toothpaste and it worked better than some of the polish kits and only cost 3$ but i finally gave in and got a pair of 1pc euro clears with hids for 200$ and had them for a year now and they look brand new and i drive about 60k a year and alott of night soo there is my 2 cents....
