corporate 14 bolt
Old Mar 29, 2012 | 02:21 PM
Shane Plummer's Avatar
Default corporate 14 bolt
i have a chance to get a corporat 14 bolt posi trac with 3.73s in it nnow but i will swap the to 4.10 i can get the whole shebang for 200 buck needs brakes and the normal stuff has anyone done this swap and if so is it a pain there is nothing wroung with my dana 60 now i just want a posi
Old Mar 29, 2012 | 02:31 PM
pukie370's Avatar
i would just find dana 60 posie carier unit and swap, it very easy to do and does not require all new gears. much cheaper and you only need a dial indicator.
Old Mar 29, 2012 | 03:15 PM
94cummins12v's Avatar
i would its a much stronger axle than the dana 60
Old Mar 29, 2012 | 07:14 PM
montepig72's Avatar
What's the application? You can get a posi or a lunchbox locker like an Aussie for the amount of money you will have in the new rear plus gears. In an effort to help and not over do it, your first gen should have a D70 in the rear which is very close to a 14 bolt, same size ring gear and bearings.
Old Mar 29, 2012 | 07:33 PM
welderboy250's Avatar
If u have a factory dodge diesel it has a 70u rear which is technically stronger than a gm14 bolt plus it's a little more versatile. Only reason I would swap is if the 14 bolt had some nice big disc brakes.
Old Mar 30, 2012 | 09:52 AM
im gonna buy a auburn cariier and new gears and bearings its to much money to swap them the lug pattern isnt the same and i cant afford new bubs too does anyone know of a good place to get the posi carrier and the gears that wont rack me over the coals
Old Mar 30, 2012 | 11:01 AM
montepig72's Avatar
Something about this is not adding up bro. What isn't the same bolt pattern? All of the dodge and gm dana/14 bolt axles have the same 8x6.5" lug pattern. The only 8 lug axles with a different lug pattern are the newer fords with the 8x170mm lug pattern. It kind of sounds like one or both of your axles are not what you think they are.
Old Mar 30, 2012 | 11:43 AM
pukie370's Avatar
first figure out what axle you have! then if your gears are the ratio you want and they look good dont change them. changing the pumpkin to a limited slipp is a easy job, but doing gears is not easy! if it dodge diesel it is a dana 70 or 80 if newer if not then if it a dana 60 it should have a 60 raised number on case, or get tag number and call a gear sales place. if you have a dana 70 keep it! if you end up buying a used posi make shure you put new cluches in it befor install.
Old Mar 24, 2013 | 01:37 PM
CUMMINStagetcha19's Avatar
For limited slip or a locker, do you need to put in the gear oil additive? I have a 92 D70 with a Detroit locker. Seems pretty stiff, any ways to check it out?
scrnnmssuck
For Sale
Apr 16, 2015 10:33 PM
Alfred Bruce Millett
Apr 3, 2015 01:45 AM
Jgloveracob
Mar 7, 2015 07:13 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
brown2294
Nov 3, 2014 10:09 PM
