Speedo and odometer not working
Old Mar 28, 2012 | 04:30 PM
Powerstroker6.0's Avatar
Default Speedo and odometer not working
Hi guys got an 06 6.0 f250 was turnin onto a hwy and couldn't get it to go over 100 km's I tried deceleration and then accelerate again nothing truck was reving upto almost 4 grand ad not switching to high gear. then the speedometer crapped out. Pulled over for a few hours and had a break for a few hours drove it again all was fine for about a day before it crapped out again left with no speedo no odometer and what seems to be a lack of power in my truck took it to a tranny shop since the speed sensor is in the transmission they could not find any codes that displayed anything even saying the speed sensor was not working. Although a code did pop up 1780 tcs which he said had to do with the tow haul function guess just another issue I will have to address. trucks got about 114 thou
On it
Old Mar 28, 2012 | 04:54 PM
bobfbigman's Avatar
The speed sensor is not in the trans, it is in the rear end housing, they can get gunked up and not work rite, pull it out and clean it up and see what happens. if it doesn't work out just replace it,
Old Mar 29, 2012 | 11:05 AM
ntmdtr3fan's Avatar
Speed sensor is located on top of the rearend housing. Pop it out and clean off. But with that many miles Id just buy a new one. Just had mine replaced for the same problems you are having but it didnt fix it. After many trips to the Ford dealership and no fix I went over the wire harness in the engine compartment and under neath the truck. I had found that the wire connection leading to the fuse box on top of the drivers side fenderwell had come loose. Pushed them back together and the made a good snap sound so I knew they came loose. After that I have had no problems with either the Speedo or Odo and no more engine crapping out on me.
Old Apr 21, 2012 | 12:03 AM
So just an update I took my f250 to ford today they diagnosed it as the ficm having low voltage they swapped out the ficm and re programed the truck oddly enough this restored the odometer and speedo truck runs way better. Now I can focus on the next issue
Old Apr 21, 2012 | 12:05 AM
Mitchell H.'s Avatar
Same thing happended to me, I popped it of and cleaned it....Didnt work. Any other suggestions?
Old Apr 23, 2012 | 10:50 AM
Mdub707's Avatar
I can't believe a FICM caused the speedo and odo to not work, WTF?
Only time I've had them stop working was when I had that overboost condition holding boost at a stop light. Truck lost power for a couple miles and gauges went to flat. It came back after driving down the road though.
Old Apr 23, 2012 | 12:13 PM
I know eh very weird even ford Said they didn't know how they fixed the speedo but it works great now so I'm happy no more limping around in a gutless ford
Old Apr 23, 2012 | 02:48 PM
Mdub707's Avatar
I would test your batteries too. Have them load tested, just for curiosity sakes. Dying batteries can produce all of these symptoms. Even if the FICM was dying, it should effect your transmission operation at all, but weak batteries certainly will, and they're known to kill FICM's. Might be worth looking over your charging system so you're not doing this again in a month.
Gizmo52
12
Mar 18, 2015 07:52 PM
jcottonoir
Oct 7, 2014 08:04 AM
