P0122 Throttle Position Sensor voltage low
Old Mar 28, 2012 | 12:36 PM
Nutty Jeeps's Avatar
Default P0122 Throttle Position Sensor voltage low
Alright guys, I got this code a while ago and then cleared it and it went away, well it came back the other day so I cleared it again, then on the way to work today my truck started acting a bit strange when speeding up so when I got to work I hooked it up and had that code. Is all it is is my Throttle position sensor?
haha nvm about the is that all it is... That things like 300 bucks
Last edited by Nutty Jeeps; Mar 28, 2012 at 12:36 PM. Reason: Automerged Doublepost
Old Mar 29, 2012 | 08:00 PM
pimba24's Avatar
A code P0122 may mean that one or more of the following has happened:
TPS not mounted securely
TPS circuit short to ground or another wire
Faulty TPS
Damaged computer (PCM)
Old Mar 29, 2012 | 08:20 PM
Jazz's Avatar
Give this a try https://www.dieselbombers.com/dodge-...ting-apps.html
I've done this a couple times and it worked great
Old Mar 29, 2012 | 08:47 PM
I knew there was a write up some where just didn't find it. Honestly haven't had a ton of time to search through it. Thanks!
Old Mar 29, 2012 | 08:49 PM
Jazz's Avatar
No Problem Bud Anything for a fellow cheese head
Old Mar 29, 2012 | 09:32 PM
1997silverado
Sep 7, 2023 06:20 PM
burndiesel
10
Feb 7, 2023 01:15 AM
robbyS
Apr 16, 2015 02:22 PM
Jmohr52
Mar 4, 2015 01:18 AM
1stgenswap
Nov 3, 2014 09:45 PM
