Price Quote - Request A Price This Forum is for Requesting Price Quotes - Upon Your New thread All Participating Vendors & Distributors Will Receive a Private Message Notifying them Of your Thread - You May Opt Out of this Option
John Deere tuner
Old Mar 28, 2012 | 08:32 AM
smokincummins92's Avatar
Default John Deere tuner
Looking for a tuner for a John Deere 7320. I dont know if anyone on here sells tuners for tractors but if you do please let me know! I have been told that some 7320's were common rail and mine is NOT a common rail!! It has what I would consider a VP44 pump. I dont know excactly what pump it is, but that is the style pump that it on it. Thanks
Old Mar 28, 2012 | 09:08 AM
RAW's Avatar
RAW
Does it look like this?
If so, that's a Stanadyne DE10 injection pump. I'm really not to sure if they can be electronically tweaked.
I did find this though:
http://shop.heavydieseltuner.com/HDT...e-HDT-DE10.htm
Old Mar 28, 2012 | 10:51 AM
Farmboy 2.0's Avatar
TS Performance 4110102 should do the trick! What year of tractor is it? Just to make sure it would be the right one
I looked at the wrong dang tractor
Last edited by Farmboy 2.0; Mar 28, 2012 at 10:51 AM. Reason: Automerged Doublepost
Old Mar 28, 2012 | 01:18 PM
No its not a Stanadyne DE10. I posted a pic of the pump below. I dont know what year the tractor is I looked it over and cant find a year anywhere, but i am pretty sure its an earlier year model cause I did find a year stamped in the wheels and the date on them is 12-6-02 so im gona say its a 2003 model.
Old Mar 28, 2012 | 01:29 PM
RAW's Avatar
RAW
Looks like it already has an extra connector in there. If that's yours, you may want to disconnect it from the pump, and run the harness behind the return line. Wires look a little tight there. On the construction side, it often caused a broken wire in the connector body.
Old Mar 28, 2012 | 01:39 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
that sure looks like a vp44
Old Mar 28, 2012 | 01:45 PM
I was just thinking the same thing!
Old Mar 28, 2012 | 02:01 PM
Yea it looks alot like a vp44! So Scott you think that the TS Performance 4110102 will work?
Old Mar 28, 2012 | 03:05 PM
Unfortunately there are no tuning systems that will work for those injection systems. I just talked to ts and they only do for the common rails. Do you know what litre engine that is?
Old Mar 28, 2012 | 03:38 PM
Its a 6.8 Litre
