AFC Banjo Bolt
Old Mar 28, 2012 | 03:44 AM
Drucifer's Avatar
Default AFC Banjo Bolt
A couple weeks ago I was letting my 12v stretch it legs one last time before pulling the motor out for my swap into my F250, as I hit 2200Rpms, and nearly at full boost, I heard a loud pop, and lost power, I limped the truck home, and popped the hood to figure out what happened, the banjo bolt snapped right where the crush washer meets the AFC top, I pulled the AFC top to inspect the diaphragm.....to find that little washer, turned into coarse dust on the top of the star wheel....
I live in Laramie, WY at this time, and nobody here seems to carry the parts I need.
I have been speaking with DennyT and will be buying the AFC delete top from him fairly soon, but still need that bolt, anyone know what thread size, bolt Diameter and length these are? mine is too destroyed to even TRY to figure out, it popped the smoke screw cap off and a small chunk of cast aluminum when it blew off, it was a pretty nasty and violent failure of that bolt.
Old Mar 28, 2012 | 06:59 AM
turbo2332's Avatar
ive got a couple extra laying around from my 95's fuel system. i will take the bolt out of the 90 and see if i can come up with anthing for you.
Old Mar 28, 2012 | 08:16 AM
ricet07's Avatar
You can build your own for the time being. I ran a home made one on my 90 and it worked great. If that is something you would consider doing let me know and I can find the old threads or just post what size tge fittings are
Old Mar 28, 2012 | 01:09 PM
Drucifer's Avatar
I didn't know you can make your own, but the motor is already pulled, and the hole is plugged so no debris can get in, Thank you very much though.
If you find one that will work, let me know price and shipping, I can pay you for it on the 1st.
Old May 3, 2012 | 10:03 AM
wileyzreserve's Avatar
ya i had to make my own to cause i was putting mine back on and tightened it just a little to much hahaha it sucked cause i couldn't find them anywhere
Old May 9, 2012 | 12:57 PM
jwirth's Avatar
Dealer still cares the part your looking for.
Old May 12, 2012 | 05:04 PM
Crazy_mtb_2002's Avatar
Mine was missing so I drilled and tapped the aft side, and ran a brake line instead
my97-6gun
May 3, 2015 09:43 PM
scrnnmssuck
For Sale
Apr 16, 2015 10:33 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
