What would I need to swap?
Old Mar 27, 2012 | 10:23 PM
firstgenfarmer's Avatar
Default What would I need to swap?
Hi I'm sure this is a commonly asked question on here but I was just curious cause the oportunity may have presented itself.
Here goes.... I would like to swap out my auto 727 in my 1991 w250 for a 5 speed Gertrag
I know i need a transmission
driveshafts front and rear
bellhousing/ starter
transfer case
cluth pedals
slave cylinder
column and instrument cluster
is there anything else im really forgeting that i really need any help would be glady taken
Old Mar 28, 2012 | 03:50 AM
Drucifer's Avatar
Other than a new flywheel, I think you've got it covered, now I'm not that into Dodge trucks, so I'm no "Pro", but I think those had primitive ECM/PCM units in them, I have no honest Idea if I am correct, but you MAY have to change that out if it would pose a problem.
I have a Getrag G260 2wd trans that's pending a trade towards an HX35, but I have the flywheel as well, if you need it, let me know, I won't need it since I'm throwing a NV4500 behind mine.
Old Mar 28, 2012 | 01:59 PM
1stgenblowingsmoke's Avatar
I think it'll be fine just to use the current PCM he may have a SES like n he may not.
OP your best thing to do would be do some research and PM some people who have done the swap and see if they changed the PCM or not. You can keep your stock gauges aswel the only difference is one has the gear indicator but it actually unscrews from the cluster to have a blank plate screwed in place.
Last edited by 1stgenblowingsmoke; Mar 28, 2012 at 02:00 PM. Reason: Automerged Doublepost
STDiesel59
Jul 11, 2015 10:09 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
F250MACH
Apr 26, 2015 05:19 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
