efi lope
Old Mar 27, 2012 | 09:23 PM
TN12valve's Avatar
Default efi lope
will efi lope tune mess up your injectors? or harm anything? ive heard its bad for the injectors and will cause them to fail prematurely. i do have aftermarket injectors. thanks
Old Mar 27, 2012 | 10:26 PM
2004LB7's Avatar
i find that hard to believe. just a small tweak to the idle fueling will cause loping. the injectors use 10 times the amount for cruising. all you are doing is causing the ECM to overshoot then undershoot the amount of fuel calculated to idle smoothly.
i think more harm will be done to the engine mounts and other parts from the engine surging all of the time before you get failure of injectors from this.
nomoney
13
Sep 26, 2015 12:04 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Cumminsmoney
6.7L Performance
Jun 26, 2015 12:59 PM
dirtymaxrens
Price Quote - Request A Price
Jan 24, 2015 08:02 PM
