need some advise
Old Mar 26, 2012 | 11:08 PM
06ford's Avatar
Default need some advise
i have a 2006 6.0 bully dog outlook an today i was pulling a pressure washer 340 gallon tank an my truck was running about 199 thats from what the bully dog said which is on stock so my question is could i do the egr cooler delete an be ok i really wanna get studs an oil cooler but thats 5-6300 an i only have 2 grand but i feel like i really need to do sumthin now so any advise would be greatly appreciated
Old Mar 26, 2012 | 11:55 PM
bobfbigman's Avatar
If you are going to do the EGR cooler delete that is the perfect time to do the oil cooler, its right there under the intake wich you are going to have off anyway for the delete. between the oil cooler, egr delete and put a coolant filter on too, that will cost you around $500 if you do it yourself. if you have the basic metric tools you should be able to do this in one day. then you will have a nice reliable truck, headstuds can wait as long as you don't push it too far,watch your EGTs. oil cooler repair kit is #3c3z-6a642-ca and they are about $250 from Tousley Ford, they have some of the best prices Iv'e found.
Old Mar 27, 2012 | 08:41 AM
Mdub707's Avatar
How much weight is the setup you're pulling? You were running 199 what? What is that supposed to be? I'm confused. Is that oil temp? Coolant temp?
199 doesn't sound that hot if you were pulling some weight around!?
Old Mar 27, 2012 | 09:09 PM
06ford's Avatar
coolant sorry i new i was gonna forget something. weight im not sure i no it was a 340 gallon tank an it was full of water an has a heater an a motor on the front so i mean its not real light but i was also coming back an had 280 gallon in it an it was runn any where from 199 up to 203 an i would get going down hill an it would drop down to 195 but just running on a straight away 65 mph the coolant was running 199
Old Mar 28, 2012 | 08:00 AM
Mdub707's Avatar
Well water weighs 8lbs per gallon so 340 gallon (if you were maxed out) x 8lbs = 2720lbs, plus whatever else you had, lets call an even 4klbs. Not a TON of weight, but enough to notice you're towing something. Honestly those temps don't sound bad to me. You're still under 200* towing...
How many miles are on this truck? An oil cooler rebuild and an EGR delete wouldn't hurt as preventative maintenance, and you could buy the parts for under $500 and do it yourself. Not hard of a job.
Old Mar 28, 2012 | 01:00 PM
06ford's Avatar
It has 132,670 on it
Old Mar 28, 2012 | 01:42 PM
Mdub707's Avatar
Yeah, I would do my last sentence up there...
Old Mar 28, 2012 | 07:22 PM
tiremann9669's Avatar
No that would be 2 TONS actually
Old Mar 28, 2012 | 11:29 PM
06ford's Avatar
What all is involved in rebuilding the oil cooler
Old Mar 29, 2012 | 12:25 AM
bobfbigman's Avatar
there is basically a heat exchanger inside a housing that has the oilfilter housing on top of it, take that whole housing off and change out the heat exchanger part. gonna have to take off the intake then the oilcooler housing is right underneath of that, a good afternoons work.
