valve spring help!!!!??
Old Mar 26, 2012 | 09:09 PM
tmonroe's Avatar
Default valve spring help!!!!??
What Lbs.valve springs do I need to run a 4k gsk . And yes I will be running valve springs so don't say i don't need them
Old Mar 26, 2012 | 09:21 PM
Haden's Avatar
Old Mar 28, 2012 | 05:48 PM
EasternAggie's Avatar
60lbs are what most people usually run with the 4k GSK, and what I'm running too. They should support you to 36-3700rpm
Old Mar 30, 2012 | 09:06 PM
tmonroe's Avatar
I herd that you only have to have them on the exhaust valves is this true?
Old Mar 30, 2012 | 10:46 PM
turbo2332's Avatar
yes... because the exhaust valve is the one that the piston chases back up the cylinder bore and hits when the valve floats. the intakes float just like the exhaust but dont hit anything when they do. spend the extra $30 or so buchs and do all 12. and much over 3600rpms even with 60's you are floating valves there isnt much difference in spring pressures.
Old Mar 31, 2012 | 03:25 PM
That's right. The real fix is a set of Hamilton springs and billet retainer/keepers, but they are considerably more expensive.
While you're in there just do all 12. If you're changing them yourself, this is the most useful tool you can buy. Works AWESOME.
TORK TOOL 12-VALVE SPRING COMPRESSOR-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Old Apr 9, 2012 | 04:45 PM
pullincrazy88's Avatar
i havent found anyone that offers a set of #60 valve springs for both intake and exhaust only exhaust
Old Apr 9, 2012 | 06:21 PM
daveO's Avatar
The springs are identical, so just order 2 sets.
Old Apr 9, 2012 | 06:32 PM
Its the same exact spring. Anyone should sell the full set of 12. I'll give Tony a little support here...
Mighty Diesel - Diesel Performance Parts For Cummins Powerstroke Duramax and More
Old Apr 10, 2012 | 12:09 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 60LB spring will work perfect for 4kgs
